Sponsored by: Real Truck
Horn / confused
Old Sep 13, 2010 | 07:52 PM
TexazF350's Avatar
TexazF350
Question Horn / confused
I was julted from sleep about 4am this morning. As my 05 F350 6.0 sat in the driveway, with the horn blaring. Not a security issue. Just blaring away. I clicked my remote unlock / lock, nodda. I opened the door, and pressed (didn't hit with anger), the horn on the steering wheel. It stopped. As I was on my way home, another driver pulled out in front of me. I pressed my horn. Nodda. Checked the fuse / fine. Clock-Spring seems to be fine (Still clicks as normal). All other steering wheel controls are still working w/ no issue. Pulled the air-bag fuse, let it sit for about 30 mintues. Pulled the bag / horn off of the wheel. Wire-connections seem to be fine. Not much of an electrical genious, but I try until I think I may mess something else up. Anyone else waken up by a horn in the middle of the night.... (horn does not "honk" when use my remote to lock / press lock 2-times)
Old Sep 14, 2010 | 10:55 AM
DavidB's Avatar
DavidB
Horn relay?
Sounds like a bad horn relay.
Old Sep 14, 2010 | 11:29 AM
TexazF350's Avatar
TexazF350
From my understanding the 05 and newer do NOT have a seperate "relay" and is actually built into the box itself. Any truth to it? Any other suggestions..
Old Sep 14, 2010 | 01:03 PM
TexasRebel's Avatar
TexasRebel
do your horns sound if you put power directly to them?
the horn button popped off of my C10 once, and the only reason that I didn't return to a dead battery is because the horn itself burned out.
They aren't really made for a long duty cycle.
Old Sep 18, 2010 | 11:09 PM
TexazF350's Avatar
TexazF350
Relay good, now is blowing fuses *after checking all electrical from Horn connection back to steeringwheel. is it the horn itself?
tap1946
May 16, 2013 06:09 PM
02mudbug
Electrical Systems/Wiring
Mar 13, 2010 06:41 PM
colorado flyfisher
27
Jan 28, 2009 09:53 AM
rfyang
Nov 23, 2003 02:50 PM
jimbo_1
Jun 7, 2000 04:46 PM
