How Fast?
Old Sep 13, 2010 | 10:22 AM
53 Meadow Green's Avatar
53 Meadow Green
How Fast?
Took my 53 out for my first drive yesterday. Too fun.
I have never driven a car this old or slow in my life!
Here's my question.
Is the F100 with the Flat Head V8 so low on power it is normal to have a tough time getting up inclines like the on ramp to the freeway and gentle hills on country roads?
Sounds like it is running fine so I doubt I have serious engine problems. Rolls great downhill so I don't think I have brake or bearing issues either. I'm going to tune her up tonite. Plugs, rotor, cap, points, Spark plug wires, oil and lube.
Will I be off to the races when I'm done?
If this is all she'll do, that's fine. I'll enjoy her charm with delightful patience.
Old Sep 13, 2010 | 11:04 AM
56panelford's Avatar
56panelford
Check your compression on all cylinders and that should give you alot of information.
P.S. you could put a bigger sail to get more speed but it will depend on the wind,lol
Old Sep 13, 2010 | 12:18 PM
blsd49's Avatar
blsd49
I have a flat 8 and a flat 6 and drive them all the time on country hills as that is all we have here. While certainly not fast, they have no problem with them.
Checking the compression sounds like where I would start also.
Good luck!
Old Sep 13, 2010 | 01:15 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Also the spark advance. It makes a HUGE difference.
Old Sep 13, 2010 | 02:45 PM
Julies Cool F1's Avatar
Julies Cool F1
Silly question, but do you have the original rear end in it? It probably shouldn't go over 55 or so if you do.
If the rear end has been replaced or re-geared to something a little higher for freeway speeds, that may make it a little harder going on the hills.
Old Sep 13, 2010 | 03:11 PM
53 Meadow Green
It has the original rear end. Auto transmission. As I ponder, it may not be kicking down as I start up the hill...gonna go see.
Old Sep 13, 2010 | 03:19 PM
Julies Cool F1
Gearing should be fine.
Check the kickdown and the tune up items the other mentioned then.
Old Sep 13, 2010 | 10:39 PM
mtflat's Avatar
mtflat
My 48 F1 with the flathead V8 runs up mountain passes out here with 3.50 rear gears. I'd say something is wrong with your setup. Look into the advice you got above.
rashdabull09
Apr 6, 2013 10:20 AM
55 f350
Feb 4, 2012 02:33 PM
richard53
Aug 3, 2010 03:25 PM
Oregon-Mike
Mar 13, 2007 02:16 PM
stepman
32
Oct 29, 2003 09:29 AM
