Radiator
Old Sep 13, 2010 | 08:52 AM
87notch's Avatar
87notch
Radiator
What kind of radiator works well on a 52 f1 with a 302?
Old Sep 13, 2010 | 08:56 AM
lgfuller's Avatar
lgfuller
griffin aluminium. like for a mustang.
Old Sep 13, 2010 | 09:01 AM
KidShalene's Avatar
KidShalene
Took my original to the local Rad shop and they re-cored it with 4 rows of core tubes, didn't want fitment issues or the hastle of fabing new mounts, etc....
They can relocate inlet & outlets too if necessary
Old Sep 13, 2010 | 04:10 PM
87notch's Avatar
87notch
This sound like the route for me. Thanks
Old Sep 13, 2010 | 04:52 PM
lvin4jc's Avatar
lvin4jc
Did that fit right in and what year mustang was it supposed to fit?
Old Sep 13, 2010 | 05:22 PM
wulleebullee's Avatar
wulleebullee
Price?
87notch, What was the cost to recore your rad?
Old Sep 13, 2010 | 07:16 PM
52 Merc's Avatar
52 Merc
The stock radiator works fine, and if it's not in bad shape, wouldn't even need to be recored. 6 cylinder radiators work better because they already have only one inlet and outlet. The only downside is you can't run a normal pressure cap on them, so you lose the benefit of the higher boiling point with 14lbs. of system pressure.
Old Sep 13, 2010 | 07:53 PM
reed1951's Avatar
reed1951
I got a 1970 mustang radiator for my 51. It fits inside the stock radiator support, all I will need to do is make some simple brackets to bolt it to the original support holes. I got it at advanceauto for like 140 bucks on an online sale.
Old Sep 13, 2010 | 08:10 PM
havi's Avatar
havi
I'll have the Roast Duck
Some have used the mid 70's Dodge radiator, and if I was using anything but a flathead, that's what I would consider first, only because I'm cheap, lol.
Old Sep 13, 2010 | 08:33 PM
hoobatech's Avatar
hoobatech
ebay has some cheap radiators as well for about 200
http://cgi.ebay.com/ebaymotors/ws/eB...=STRK:MEWAX:IT
Old Sep 13, 2010 | 09:11 PM
lvin4jc's Avatar
lvin4jc
Perfect, thanks
Old Sep 13, 2010 | 09:17 PM
havi's Avatar
havi
Originally Posted by lvin4jc33
Perfect, thanks
Do a search on this forum with dodge radiator, you might get more info.
Old Sep 14, 2010 | 05:48 AM
49willard's Avatar
49willard
I am using the Dodge radiator with a sbc however. The bottom hose is on the passenger side and the top hose is on the drivers side (right hand drive truck!). Pic in my gallery.
Old Sep 14, 2010 | 08:47 AM
lvin4jc's Avatar
lvin4jc
Yeah, that's what I see from doing a search on it. Everyone's doing it with a sbc and my sbf water pump has the lower hose exiting on the driver's side and the upper is on the pass. side.
Old Sep 14, 2010 | 04:51 PM
87notch's Avatar
87notch
I'm pretty sure that a water pump for a 69 bronco 302 exits on the passenger side, if you want to go through the trouble to change it.
