shackle reversal kit
Old Sep 13, 2010 | 11:09 PM
  #31
Dave Sponaugle's Avatar
Dave Sponaugle
I think I would bolt them to the frame.
If you ever want to go back, or make the lift shorter, just unbolt and work on it on the bench.
Old Sep 13, 2010 | 11:28 PM
  #32
oreocreaming's Avatar
oreocreaming
if i ever wanted to go lower, just throw some psd stock springs on her (i got 2 sets just takin up space lol) and with the way you gotta cut the inner shackle housing theres no goin back.
Old Sep 13, 2010 | 11:29 PM
  #33
oreocreaming
OR, can always drill new front hanger holes and bring it down as low as 0" lift and still have the rear shackle
Old Sep 14, 2010 | 02:56 PM
  #34
oreocreaming
think i found a way to save another $85 bucks! instead of buyin skys front shackles, im just gonna take the ones off the rear and throw them on the front axle. its exactly what im lookin for, and its a 4 1/2" eye to eye lift. the ones from sky are only 5" so its super close. might just have to throw a small shim on the axle. will find out once shes all said and done. figure, since im getting the lift shackle for the rear anyways, reuse parts huh? woohoo!
Old Sep 15, 2010 | 02:35 AM
  #35
oreocreaming
well, shes almost done. all welded up now, gonna remove the rear shackles and put em up front.... see how she does. i decided to only go 4 1/2" inch in the front. match the shackles. gotta order the new rear shackles now, frickin 90 bucks, but it will give me an extra 1" rear lift. try and level the truck out.
Old Sep 15, 2010 | 07:14 AM
  #36
mechelement's Avatar
mechelement
Are you going to box them in or rib that bend? How did you bend the steel? Did you anneal it after bending it?
Old Sep 15, 2010 | 12:33 PM
  #37
87crewdually's Avatar
87crewdually
Hope you got a base line degree reading for your caster and match it at the least, or that thing will wonder like a gypsie. If your degree reading was -5*, I'd go -6* to compensate for the reversal. Of course all this can be adjusted with shackle length.
Old Sep 15, 2010 | 02:33 PM
  #38
mabc926's Avatar
mabc926
Can't wait to see the lift done!
Old Sep 15, 2010 | 03:49 PM
  #39
oreocreaming
bent it the old fashion way since our iron worker would only do a slight bend in that 1/2" plate. no, im not going to box it, theres not much gap there to make it worth while BUT im going to run a 1/4" plate from inside to inside. that will give it plenty of cross support and help push the air upward to the intercooler.
no, i didnt bother to get a baseline on pitman angle because i wouldnt go by it anyways. im gonna be around 5 degrees and see how she does. its all going to be controlled with a shim.
Old Sep 16, 2010 | 08:06 PM
  #40
Coalroller's Avatar
Coalroller
oreo... a couple things
1)i pry asked you before, where did you end up gettin your body lift blocks from
2)where did you get that sumner jack from they would really come in handy
3)here is somethin you might be interested in Ford Dana 60 Ball Joint Crossover Steering Convers - Sky's Off-road Design
Old Sep 16, 2010 | 08:14 PM
  #41
oreocreaming
1 ebay and just got the bolts from a place that only handles bolts.
2 it's actually just a pipe stand that my old company uses for welding pipes on. We have the roller heads for them. 2500 lb capacity each. Bad a$$.
3 I've got kingpin d60, not balljoint. Thanks though. I'm lookin into crossover steering.
Old Sep 16, 2010 | 08:19 PM
  #42
Coalroller's Avatar
Coalroller
were they just a universal block? and yeah they are pretty freakin sweet!. gotcha i was on their site and lookin around and saw them what year did they go to ball joint if you dont mind me askin?
Old Sep 16, 2010 | 09:29 PM
  #43
oreocreaming
yep, 3x3 block. cheap man. they were like 8 each when i was gonna do the first body lift. this new guy has em for iirc 4 each. dont know what year they made the switch.
Old Sep 16, 2010 | 09:32 PM
  #44
oreocreaming
Old Sep 17, 2010 | 06:16 AM
  #45
Coalroller's Avatar
Coalroller
thanks man!
