piston flower pattern
Old Sep 12, 2010 | 08:12 PM
crazer42's Avatar
crazer42
on some rebuilds i see the flower pattern burnt out side of the bowl what causes this, is that considered damage?
Old Sep 13, 2010 | 12:21 AM
Pocket's Avatar
Pocket
Advanced timing. It causes the injector to spray earlier and outside of the piston bowl.
Even the stock tuning advances timing when oil temps are cold. Those with stock trucks that drive short distances often, or live in colder climates, will probably see these patterns more often.
Chips and tuners can advance timing as well, although most tunes I've seen are pretty moderate with their timing advance. In addition, most tunes leave the stock cold advance untouched.
Some folks may disagree with me (and that's fine), but I personally back down the timing advance table considerably in the tuning, especially on higher HP tunes. The result is a little more white smoke on cold starts, but I don't have that damn death rattle when the engine is cold either. Even in stock tuning, it rattles when temps are cold if that table is left alone. I hate it. I'd rather deal with a bit more white smoke for the first 2 minutes of driving, and have a nice quite engine that sounds like it's fully warmed up from the instant I start it.
Old Sep 13, 2010 | 08:23 AM
SuperDoodie's Avatar
SuperDoodie
You're spot on Curtis
KOESTNER
Illinois Chapter
5041
May 31, 2014 10:31 PM
KOESTNER
Illinois Chapter
136
May 31, 2012 08:21 PM
KOESTNER
Illinois Chapter
166
May 3, 2012 08:02 AM
PreciousOne
West Virginia Chapter
109
May 31, 2011 09:51 AM
dustybumpers
Maryland Chapter
1535
May 1, 2010 12:11 PM
