Sponsored by: Auxito
cruise kicks off while pulling a load
Old Sep 12, 2010 | 08:02 PM
thundersnow70's Avatar
thundersnow70
i have a 2001 supercrew with a 5.4, auto and four wheel drive. it has 130,000 miles on it and a fresh tune-up,all 8 coils,plugs,injection cleaning, etc. when i pull a big hill with the cruise on, mostly with a trailer full of toys, it will down shift to third, run up to 3 or 3500 rpm and then before i get to the top of the hill the cruise kicks off. it seems to run fine, the cruise always turns back on, its just kind of a pain. all i can think of is a knock senser, but i have never heard it ping? maybe i should try some high octane gas. i'm sure there are some smart people on here that know what is causing this so thanks in advance for the help! PS the truck has stock everything, tires, gears, etc
Old Sep 13, 2010 | 06:01 AM
projectSHO89's Avatar
projectSHO89
Normal. See "Speed Control" section of your owner's manual.
Use your right foot when driving in hills with a load.
Old Sep 13, 2010 | 07:06 AM
Big Greenie's Avatar
Big Greenie
Temporarily Deactivated
Agreed, normal. If the truck loses enough speed on the hill it will shut off the cruise and you have to reset it once back up to speed.
Old Sep 13, 2010 | 12:43 PM
Bluegrass 7's Avatar
Bluegrass 7
Using CC towing heavey loads amounts to engine abuse in my opinion.
You have to accepts some speed change while towing to be reasonable.
Old Sep 13, 2010 | 07:20 PM
galaxie641's Avatar
galaxie641
Cruise will usually kick off after losing 3-5mph, you really should take a bit of a run at the hill if it is pulling you down that much.
Old Sep 15, 2010 | 06:18 PM
thundersnow70
thanks for the advice, never thought to look in the manual. figured something was wrong as this is the first truck i have had that this has occured. kind of feel stupid now! Thanks again!
4X4HB
Jul 23, 2013 03:00 PM
SilverSS
Jul 12, 2013 02:34 PM
A/Ox4
2004 - 2008 F150
Feb 4, 2010 07:54 PM
mtrotte
Sep 30, 2008 12:54 PM
SDElwood
May 13, 2003 01:40 PM
