INSTALLING UP PIPES
Old Sep 12, 2010 | 09:39 AM
johnsjsj's Avatar
johnsjsj
INSTALLING UP PIPES
WHEN INSTALLING NEW IH UP PIPES DO YOU REMOVE THE TURBO OR CAN IT BE DONE FROM ALL UNDER THE TRUCK. DOES SOME ONE HAVE A DETAIL STEP BY STEP PROCEDURE?
Old Sep 12, 2010 | 09:49 AM
ron's power stroke's Avatar
ron's power stroke
i had no oil leaks at the time so i left the turbo in
Welcome to Pocket's International UP-Pipe Replacement Web Page
Old Sep 12, 2010 | 10:35 AM
Pocket's Avatar
Pocket
I'm sure you could do it without removing the turbo, but it would take way more time. At least it would for me.... my big hands don't fit very well in tight spots.
Pulling the turbo doesn't take very long.
Old Sep 13, 2010 | 08:31 AM
03_PSD's Avatar
03_PSD
I used the link Ron provided, worked like a charm.
Pretty easy job, just time consuming.
Old Sep 13, 2010 | 11:06 AM
stangclassic66's Avatar
stangclassic66
How on earth did you do that without removing the turbo?
This is a job i'm tackling in the next couple/few months and I'm not sure if it's possible with the turbo in the way. My turbo doesn't leak either so if it's possible I may go this route as well.
Old Sep 13, 2010 | 03:05 PM
viking89's Avatar
viking89
Another endorsement for Pocket's guide.
Old Sep 13, 2010 | 03:33 PM
ron's power stroke
lol have a platform in my shop when i drive into it..the platform goes from driver door around the front and to the pasanger door and big enough for my tool box and a little work bench.....everything under the hood is at my hight.....a sharp air chisel and a cute off wheel took car of the rest...all you need is for one pipe to come out and the rest will go the other way...
Old Sep 13, 2010 | 05:27 PM
bobbyrjw's Avatar
bobbyrjw
I am in the middle of installing up-pipes, wicked wheel, and FRx now.
https://www.ford-trucks.com/forums/9...tallation.html
A saws all may help you get the pipes off without pulling the turbo. Pretty tight.
