Is it worth pulling?
Old Sep 12, 2010 | 08:12 AM
amishbuggy116's Avatar
amishbuggy116
Hi, there is a bone yard that I go to about once a week on saturdays (it's 45 miles from home), the place is huge. I started going there originally to look for parts for my Bump but soon found myself hooked on grabbing anything old. Anyhow I was there yesterday and way back in the woods I found an old bump with a perfect dash pad, what a score because mine has a crack in it, sitting next to the bump is early 60's F series with a padded dash, it's sooo cool I wish my truck had curves like that, the dash however has a crack between the left vent and the windshield. Is this something that would be worth pulling? I hate to see this stuff rotting away in the trees.
Thanks alot
Pat
Old Sep 12, 2010 | 08:59 AM
gangstakr's Avatar
gangstakr
Depends if the pad is dry and brittle. Any hard areas on pad will crack with a little preasure on it. Apply preasure on various parts of pad, if cracks appear it's no good. Because these pads are affixed with glue, removing it will be a challenge. You'll also be able to see if new cracks appear. Bump pads are held down with nut's and studs and are easier to remove. The early pads are held with glue and prying them up will reveal the dryness of pad. Good luck
Old Sep 12, 2010 | 09:05 AM
amishbuggy116
Thanks for the info, holy cow they glued them, I guess that makes sense with all them curves, maybe I'll give it a shot.
Thanks alot
Pat
Old Sep 12, 2010 | 04:41 PM
customcab66's Avatar
customcab66
i took my dash pad off and just cover the dash with some material and i like it alot better that the pad they used
Old Sep 12, 2010 | 04:54 PM
amishbuggy116
You may be right but I think the pad is really good looking, I like the lines and where it meets the paint is great. I think if the pad was cracked all over the place then it would be an eyesore but man when the pad is good I don't think you can beat it.
Gary Lewis
62
Oct 19, 2015 02:42 PM
Cardinal Puller
Aug 11, 2015 03:28 PM
shortwide
15
Aug 30, 2014 02:04 PM
Keithfriend
Jul 3, 2014 06:33 PM
pgr380
Aug 21, 2011 04:45 PM
