6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Nitrogen filled tires...
Old Sep 11, 2010 | 06:46 PM
nomorecummins's Avatar
nomorecummins
Anybody running Nitrogen in your tires? If so, what is the big difference between Air and Nitrogen?
Old Sep 11, 2010 | 08:03 PM
96psdiesel's Avatar
96psdiesel
Nitrogen is inert it doesn't expand or contract based on temperature conditions. Basically unless you have a leak your tire pressure should remain constant when filled with nitrogen.
Old Sep 11, 2010 | 08:06 PM
03silverTJ's Avatar
03silverTJ
I have seen it argued both ways. Worth it and not worth it. Personally I think it is a scam to get you to pay more money to have someone put a gas into your tires...
Here is a great thread on it https://www.ford-trucks.com/forums/9...-in-tires.html
Old Sep 11, 2010 | 09:20 PM
Biggziff's Avatar
Biggziff
Snake oil
Car Talk
Old Sep 11, 2010 | 10:43 PM
Painted Horse's Avatar
Painted Horse
Dealer tried to get me to buy this when I picked up my new truck. Personally, I add air and let air out as I change what I'm towing or if I'm running empty. The Nitrogen would last about 2 weeks and be totally diluted with regular air.
I see no need for it.
Old Sep 12, 2010 | 01:50 AM
cartmanea's Avatar
cartmanea
pV=nRT - Ideal Gas Law
Nitrogen still changes pressure, just not as much. Not worth it.
Old Sep 12, 2010 | 03:27 AM
adamtheman16's Avatar
adamtheman16
Thats exactly the proper way to do it.
Old Sep 12, 2010 | 10:27 AM
galaxie641's Avatar
galaxie641
Good for race cars, not much else.
Old Sep 12, 2010 | 11:39 AM
Nipperdog's Avatar
Nipperdog
I got nailed for an extra $25 when I picked up my truck. Stealer claimed that he puts nitrogen in all the vehicles before they are sold, like it or not. I got a compressor set up in my garage and don't need nitrogen filled tires. It's just a scam to put extra $$$ in the dealers pocket.
Old Sep 12, 2010 | 01:32 PM
percyad's Avatar
percyad
Originally Posted by Biggziff
Snake oil
Car Talk
I second this - anyone that has taken basic high school chemistry knows that air is 78% Nitrogen and that all gasses expand and contract with temperature. So the only issue is the inertness of pure nitrogen vs. the 78/20/2% ratios of nitrogen/oxygen/other in air.
Where nitrogen makes a big difference is at extremely high pressures where the 18% oxygen in air affects the rubber and other materials. But it's a non-issue at 65 PSI.
Save your money and put a good coat of wax on instead.
Old Sep 12, 2010 | 01:43 PM
ChargersFanInCO's Avatar
ChargersFanInCO
I run a mixture of 78% nitrogen and 22% oxygen mixed with other inert gasses....aka Normal Atmosphere...It's FREE!!
Old Sep 13, 2010 | 09:55 AM
smi33901's Avatar
smi33901
N2 in tires
Nitrogen is great if your driving at or above 30,000 feet. The reason nitrogen is used in tires it contains no moisture to freeze. Who would want to land an aircraft with Frozen tires.
Old Sep 13, 2010 | 01:47 PM
bterry's Avatar
bterry
We run it in my race car. Not uncommon to see tire temps near 200 degrees F. Pressure will rise 3-4 pounds even with nitrogen on that car - that makes a big difference to us. I do not use nitrogen in anything else, even though I get it for free from a sponsor of mine. Thanks Airgas!
THOM/CJ KR 350
May 6, 2017 08:41 AM
gascan
Oct 28, 2016 11:12 AM
Jeitutis
Oct 18, 2016 04:00 PM
jimdad07
Jul 26, 2016 03:40 PM
AllAboutDaZ
Mar 4, 2016 06:03 PM
