idle problem with straight pipes
Old Sep 11, 2010 | 06:07 PM
matthew petrovic's Avatar
matthew petrovic
i have a '95 f250 with a 351w and recently straight piped it. it has no cat it is true duals right off the headder flange. i knew that after that it would throw a code now and then and that dosent bother me because it only hapeens after an hour of it running. but somtimes in city driving if i sit at a red light long enough while in gear with my foot on the brake it will start to chug and idle rough (sounds like it has a radical cam) i kinda figure shes running a bit rich and i was just wondering if there was somthing i could do to get that to stop and keep my duals on it. i was thinkin a hotter ignition or better intake. just wondering if anyone else has had this problem with straight pipes
Old Sep 11, 2010 | 06:55 PM
lew52's Avatar
lew52
Where did you put thr O2 sensor ??.....Lew
Old Sep 11, 2010 | 07:57 PM
86F150302's Avatar
86F150302
X2 did you put the 02 back on?
Running straight pipes with no cats shouldn't give you a CEL.
I would check the codes. IMO something else is causing this problem not the exhaust.
Old Sep 12, 2010 | 07:59 AM
matthew petrovic
the 02 sensor is in its factory location right before the flange where the cat was bolted to. i made my own flange to fit that for the duals. and its not the check engine light im concerned about its the way it runs if it idles to long while in gear. at stop lights if i sit to long and do not put it in nuetral it idles rough
Old Sep 12, 2010 | 11:22 AM
White 97 xlt's Avatar
White 97 xlt
You "should" be concerned with the check engine light..... Have you checked the trouble codes?? That is going to be the best way to find out what's wrong...
Old Sep 12, 2010 | 01:25 PM
matthew petrovic
i know the check engine light is for the o2. it onjly comes on after driving along time and i ran my scanner on it and it came up as an oxygen sensor
Old Sep 12, 2010 | 11:08 PM
TexasGuy001's Avatar
TexasGuy001
I agree the straight pipes are not causing the poor running condition. Its related to the trouble code. There could also be another issue as well.
mikeismadness
Exhaust Systems
17
May 29, 2015 11:58 AM
VaFordman26
Jul 15, 2014 12:44 PM
Trailblazed
13
Feb 17, 2008 10:32 PM
JBradley500
Exhaust Systems
Dec 31, 2006 11:47 AM
idgit0488
Exhaust Systems
Jul 6, 2006 02:54 PM
