please confirm
Old Sep 11, 2010 | 05:49 PM
14psd's Avatar
14psd
please confirm
Ok now that all the vc plugs have been changed outside the gasket, vc gaskets changed, uvcw pigtails changed/checked (some were replace last fall), and I still have white smoke. It is not antifreeze I smelled it, it is diesel fuel. I have checked the oil and I do not appear to be losing any Do I have one or more injectors leaking? That is my only guess at this point.
Old Sep 11, 2010 | 08:51 PM
plgebbia's Avatar
plgebbia
Is the smoke still there once the engine is warmed up? if so, a leaky in jector is possible, but it is also possible that you have one cylinder low on compression. I just replaced a motor for a guy that had one cylinder that had 75psi of compression, and it blew a constant haze of white smoke.
I don't know if the bad cylinder thing is possible in your truck, I just thought I would throw it out there. I sincerely hope that is not the problem.
Old Sep 11, 2010 | 09:34 PM
14psd's Avatar
14psd
you and me both!! I'm hoping its just injectors. The trucks gets up and goes still. Yeah I can drive 20-30 minutes get the truck warmed up and come to a stop light and there's my white smoke.
Old Sep 11, 2010 | 11:16 PM
plgebbia's Avatar
plgebbia
At idle when the motor is warm, does the motor shake at all?
The truck that I replaced the motor in still ran half way decent....
See if the motor is shaking, that will help to know what is going on. and hopefully someone knowledgeable about leaky injectors will chime in!
Mowing Man
Dec 21, 2013 06:38 AM
ediaa
Jan 7, 2010 11:11 AM
jimwilsonmasonry
Oct 18, 2009 10:27 PM
TransplantX
Sep 13, 2008 11:42 PM
TransplantX
Aug 30, 2008 08:00 PM
