302 Rebuild
Old Feb 19, 2003 | 11:10 AM
Border3899's Avatar
Border3899
302 Rebuild
I am going to be rebuilding my 302 in my pick up, and i'm wondering what i can do to it to beef up the performance on it. One thing i'm going to do is bore it 30 over but i would also like to perform some other mods to it. What are some things you folks would recommend i do for performance. I realize there are probably several things i can do, but some suggestions would be great.
Old Feb 19, 2003 | 09:33 PM
speedkingf100's Avatar
speedkingf100
302 Rebuild
You could get a high torque cam if you use it for pulling or maybe a hot street cam if you like to race a little, a port and polish job on the intake and exhaust ports, a nice four barrel edelbrock performer intake a 550 holley vacuum secondary up top, a set of headers (not Cheap) and some flat top pistons (make sure the compression ration does not go above 9.5 to 1 or you will be very unimpressed.)
Just my .02
Steve
PS also if you are made of money you could also buy a 347 stroker kit
Old Feb 20, 2003 | 04:54 PM
Border3899's Avatar
Border3899
302 Rebuild
Thanks Steve, i'm going to check out the four barrel intake tonight. so far what i'm going to do is port and polish the exhaust ports and the heads and install a factory roller cam out of a mustang 5.0, thinking about a new throttle body too.
Old Feb 20, 2003 | 05:59 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
302 Rebuild
you can not just swap a factory roller cam into a block that did not come with one.
Old Feb 20, 2003 | 07:40 PM
Border3899's Avatar
Border3899
302 Rebuild
What would need to be done to put in a roller cam? This is my first rebuild so i'm asking even if it's a no brainer...
Old Feb 21, 2003 | 05:55 AM
Diesel_Dummy _
302 Rebuild
a roller cam block
Old Feb 21, 2003 | 08:43 AM
PigFarmer's Avatar
PigFarmer
302 Rebuild
Depends on the year of your block. Someone here knows the exact year but sometime in the late 80's the blocks used in trucks were roller cam blocks but only had the flat tappet cam/lifters installed. In this case there are conversion kits to make the change-over.
Randy
Old Feb 21, 2003 | 09:12 AM
Border3899's Avatar
Border3899
302 Rebuild
The block is a 91, do you know if this is a roller cam block?
Old Feb 21, 2003 | 12:06 PM
PigFarmer's Avatar
PigFarmer
302 Rebuild
I THINK it is. Can someone confirm this??
Randy
Old Feb 21, 2003 | 05:46 PM
Diesel_Dummy _
302 Rebuild
only one way to find out , take the intake off, if it has roller tappets then its a roller block , and no ford did not use flat tappet cams in roller blocks.
Old Feb 21, 2003 | 06:46 PM
PigFarmer's Avatar
PigFarmer
302 Rebuild
Hmmm. Maybe so on the no-roller block. I've heard it mentioned more than once on here that they used what I described in the 302 trucks starting in 88. Check this threadhttps://www.ford-trucks.com/forums/s...t=roller+block DeGideo talks of such a thing. Also do a search on roller blocks in this forum. I know there's others that make reference to it. If nothing else send DeGideo a personal message thru this site and ask him to verify for you.
Randy
Old Feb 21, 2003 | 08:11 PM
Rcmgiasson's Avatar
Rcmgiasson
302 Rebuild
first have it balanced and some blueprint work done at the machine shop. This makes the bottom end almost bullet proof in a street aplication. Then you can worry about bolting on the horsepower. First you must start with a good foundation.
Old Feb 21, 2003 | 08:50 PM
V10KLZZ71S's Avatar
V10KLZZ71S
302 Rebuild
You could use a CRANE CAMS retrofit kit to install a hyd roller cam in a non-roller block
Old Feb 21, 2003 | 09:36 PM
Diesel_Dummy _
302 Rebuild
you sir are right !
my 90 5.0 is a flat tappet block and has the shorter lifter journals and no taped holes under the intake manifold for the roller lifter retainer/guides
i do however have a 89 Mustang GT 5.0 HO roller block and GT40 heads waiting for some warmer weather to be installed in my truck.
Old Feb 22, 2003 | 07:38 AM
PigFarmer's Avatar
PigFarmer
302 Rebuild
From what I've been led to beleive is that these era blocks could have the retainer bosses tapped at a machine shop and utilize the OE type roller-lifter units vs. the need for the retro lifter units needed for the older blocks. The cost of machining should be minimal. The retro's would be an option too as would just finding a fully settup roller block.
Randy
