6637 install- Anyone have pics. of breather box detail/notch for an '02
Hey all, does anyone have pictures or know a link that can show me the breather box detail to fit the 6637 in? I have an '02 which requirers this but not sure how much to cut. I know I can cut a little, check it, cut a little more, check, cut a little more---- you get the picture............ Should I just cut the whole thing off behind the battery? Looks to me like it may need a little support some where though, that's a big filter to just be sticking out there in space? Anyway, I'd appreciate some in-put!!!!
Corey
Corey
Just cut the whole thing off behind the battery hold-down.
Thanks, Clay! I sure appreciate it!!!! I also want the say thanks for the help on the other MOD's that are now complete...... AIH delete and the CCV kit...... I'll be ordering the 4" exhaust from you withing the next two weeks hopefully. I was looking under my truck just wondering how much time it would take to put the new ehaust on, all looks pretty simple until you look up the pipe going to the engine? What's the best way to get up/down there? Pull turbo off?
Corey
Corey
Got it done and I appreciate all the help! Not sure what is different but I have an '02 crew cab 4x4 and I didn't have to cut anything on my battery/breather box. I didn't even take anything off the battery side of the assembly as David did??????? When I took the breather off I noticed two 8mm bolts in the bottom of the box, took them out but it was still attached between the battery and the breather. kinda pried the plastic back, saw two more of the same bolts. Took them out and the breather box side of the the thing just popped right off. 6637 slid right in there snug as a bug.......... The battery still has it's entire cover on, the whole thing looks like was meant to be that way and 6637 is resting in there very solid with no movement. Wish I could post pics but I can't yet! Not sure how many models are like mine but there was no reason to cut or remove anything from the battery side................
Damn, I've got to ask another silly question!!! I'm new hear and to a diesel so what's a zoodad mod????? I haven't ever heard of this one! I've done the AIH delete, 6637 install and the foil delete. Hope to order my 4" exhaust for Clay this week and then get a DP turner on the way..........
Was just wonderin if anybody knew how much cfm the 6637 flows and if it is worthwhile to go with that "Big Boost" washable filter they be advertisin as an upgrade on Riff Raff?
Dont like washables really, but broke the tab off my airbox and need somethin quick cuz the roads I travel to hunt camp get pretty dusty.
