Ford branded DEF prices WAYYYY up
Sorry i posted this in the wrong spot
If you call in advance and speak with the parts guy most ford dealerships will give you a big discount to buy FORD products I bought the FORD brand def for about 22 bucks for the 2.5 gal jug
Yes, if you have bad DEF you have to drain and refill. Unfortunately the tank does not have any handy way of doing that, like a drain, so you have to siphon it thru the filler.
Im not sure on the exact details, but you have some time (at least a few hundred miles) before it goes into a actual limp mode (i.e. idle only). I do believe you are immediately limited to 55 mph though...
on
That's what I was thinking. I know some guys are carrying around a gallon in the back of the truck but that has to be a pretty poor storage environment. Just when they go to use it, it's going to be very weak or worse, useless. I'm at 5,000 miles now and my DEF gauge says less than half full. I think it would be wise to simply fill it up when it's at half level. That way I'll always have enough to get wherever I'm going.
The truck monitors NOx reduction and if it does not see what it expects to see it will then let you know the DEF is not doing its job.
I assumed that from this they could pump it empty?
Assume gets me in trouble too often though
A little information is sometimes dangerous.
Bob
IDS Techtips
Bob
Bob
Blue and White
04-25-2015 09:20 PM
