Is it possible to clean/paint engine while assembled?
Old Sep 16, 2010 | 02:10 AM
ihateminimumwage's Avatar
ihateminimumwage
Originally Posted by Friesian-Bronco
An alternative to spendy tranny jacks are lifts made for motorcycles... cheaper, and it works great.
G.
That's what I used to drop and install my C6 & NP205 combo out of my 79. Worked great, no chain to keep it from rolling over on you, but it's all I knew at the time...
Old Sep 16, 2010 | 04:53 AM
havi's Avatar
havi
I'll have the Roast Duck
As a reminder, everything I said was only for painting, not pressure washing. If you paint the lower half of the block, the motor mounts will need to be removed. If you are also painting the oil pan, then it can't rest on that either(I don't recommend resting anything on the oil pan). Now if I was to do it myself, the trans and engine would be separated from each other, and each put on a stand (buy the biggest one, don't waste money on the lighter duty ones & same stand for trans, only put nuts on the back end of the bolts instead) throughout the entire process. And to make clear, the paper towel is only for paint overspray, not pressure washing, for obvious reasons, lol.
HkyswiM
Dec 5, 2013 10:02 AM
F-250 Super Duty
46
Jul 20, 2011 08:02 PM
nagetech
Jun 1, 2011 09:45 PM
guthrie&co
Appearance & Dress-Up
Mar 4, 2006 05:52 PM
SJHanlo
16
Feb 20, 2005 08:57 PM
