Question on keys
A.) Is a little tricky but Ford ign/door 1959-69
127DP keyway
Equivale t part numbers;
Ilco - 1127DP
Dominion - 127DP
Taylor - 127DP
Curtis - H27
Star - HFD4
OEM - Hurd # 9524
B & S # 32838
127DP keyway
Ilco - 1127DP
Dominion - 127DP
Taylor - 127DP
Curtis - H27
Star - HFD4
OEM - Hurd # 9524
B & S # 32838
or B.) Ford, Mercury & Lincolns ign/door 1952-54.
127 keyway
Equivalent Part Numbers
Ilco - 1127
Dominion - 127
Taylor - 127
Curtis - H14
Star - HFD1
OEM - HURD #9070
B & S # 32553
127 keyway
Ilco - 1127
Dominion - 127
Taylor - 127
Curtis - H14
Star - HFD1
OEM - HURD #9070
B & S # 32553
Thank you, Moe.
But I still find it odd that the 1960 F600s that I have use a key that was supposedly obsolete in 1960 (key B). And two of them have the "key tag" that came with them.
Here is Ilco's 1940 to 1980 Automotive blank chart in pdf format:
http://www.kaba-ilco.com/key_systems...ttachment=True
The problem with these keys is that they are so small, most newer key machines have a hard time getting them to hold. I got some blanks, since nobody here had them. When they cut a key, the blank was in crooked and the cut was off. After about 15 minutes with a 3 sided file, I had an extra key that works great.
It's one of those things that they did to make it more secure in later years. The early key (B) had less security then the (A) style. Added grove in the A type it can still work in the B socket. When keys are used with locks that are different cut, then the tumblers are worn.
I used the Ilco 1125H and it works fine. According to Ilco's site the 1125H is the proper blank for 1940-51 Ford Ignition and door. This is the same blank listed for Mercury and Lincoln.
toys4dlr
Sep 21, 2024 06:44 AM
Tylus
2004 - 2008 F150
74
Oct 25, 2019 02:18 AM
