Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
conduit/guage wire
Old Feb 18, 2003 | 08:48 PM
PATS2002's Avatar
PATS2002
conduit/guage wire
I want to run at leat two twenty amp circuts to my attached garage.Which electric wire should I use ?? (guage 14/2 16/2) I think ?? I need one circut to run my compressor. The other for outlets for hand tools. Thanks
Old Feb 18, 2003 | 09:00 PM
Howdy's Avatar
Howdy
conduit/guage wire
If it was me, I'd find a local electrician so HE could tell me to run at least 12 gauge wire for a 20 amp circuit. He could also probably tell me anything else special I might need to know, like the code and permits, ect. I might also find out at the same time how reasonable it is for him to do the job if I do most of the prep work.
Old Feb 18, 2003 | 09:04 PM
Torque1st's Avatar
Torque1st
Posting Legend
conduit/guage wire
Good reply Howdy
Safety First!
Old Feb 18, 2003 | 10:03 PM
79Lariat's Avatar
79Lariat
conduit/guage wire
I had an electrician do mine. He ran one wire bundle into a sub panel, then split it for 220V for the welder, and 110V for everything else. It looked, and worked great when it was done, and I know it's done right (read safe).
Old Feb 18, 2003 | 11:39 PM
1pump's Avatar
1pump
conduit/guage wire
It's not that tough to do safe wiring. But if ya gotta ask a question like "which gauge", you need an electrician. I'm not slammin' you, but you gotta have some knowledge of electrical codes and safe practices before you add circuits.
Old Feb 19, 2003 | 08:21 AM
tumbleweedd's Avatar
tumbleweedd
conduit/guage wire
What i would do is bury at least a 1 inch pvc conduit for power to a sub panel and a 3/4 inch pvc conduit for phone and cable ect. even if you dont need it now at least you can add more later. If your not sure how to do the work hire it done.You can probaly save some money by checking the codes and installing the underground conduit yourself
Old Feb 19, 2003 | 05:42 PM
BB's Avatar
BB
conduit/guage wire
I would really hire an electrician to do this, it’s not worth getting electrocuted. He will probably recommend running 240V to a 60 amp GFCI subpanel in the garage and then branch off from it. Then you will have plenty of power for your tools, lights, compressor and welder.
Barry
Old Feb 19, 2003 | 09:54 PM
Mil1ion's Avatar
Mil1ion
conduit/guage wire
Figure out the length of wire you need from House to garage first.
Old Feb 20, 2003 | 05:46 PM
engineguy's Avatar
engineguy
conduit/guage wire
As luck may have it, I am an Electrician by trade. I would actually do what tumbleweed said. If you can, run a 1" pvc conduit to the garage. Pick up some #6 awg NMWU lumex wire long enough to suit your needs. LB it into your house, LB it into your garage and right into a 60 amp or bigger 12 cct or more panel. Feed it from your house panel with a 60amp 2 pole breaker. Get an electrician to check it out(to be safe). Then you got a 60 amp service in your garage. If you can't do that, make sure you run at least #12awg wire to what you want to do...
PineViewlandscape
Mar 1, 2011 03:29 PM
Brother Les
Jul 19, 2010 01:44 PM
*2fords*
May 9, 2010 08:55 AM
Hotairjunkie
Electrical Systems/Wiring
Jul 9, 2009 11:03 PM
adamzelazowski
Feb 24, 2009 12:40 PM
