MY OFFICAL ENGINE REBUILDING THREAD
Old Sep 7, 2010 | 10:11 PM
Big-old-460's Avatar
Big-old-460
Arrow MY OFFICAL ENGINE REBUILDING THREAD
Well as you all know i am in school .. for automotive.. at the T-ten training center. plan to work for FORD Motor co . once i am out...
My truck engine got accepted as the class project...
I will be bringing in my 460 7.5 v8 1994 efi to school
we will tear the engine out and basically rebuild it...
I haven't really decided ,, What build i will go with ..
Stock 460s Put out 390 tq and 230 hp to the wheels not the Transmission.
Trying to add bout 100 to TQ and HP.
i am also ASE certified in engines and auto electrical
I will be posting pics on the rebuild.. etc
so keep an eye out on this thread......
NEED ADVICE ....... i will repaint the engine * eastwood * dark ford blue and ... black.. I am looking for a paint.net pic or a perfect 460 pic that i can test/modify colors on .. thou my pant shop program.. any ideas ?
wish me luck truck gos in school shop tomorrow...
Old Sep 8, 2010 | 02:04 AM
sufferingant's Avatar
sufferingant
Do a high compression build.
Old Sep 8, 2010 | 07:20 PM
Big-old-460
OK well .... I need something for off roading.. and Mudding... the only Question is do i need high torqe or high HP and at wat rpm range ,, any help would be great thxs
jayson
i need honest experienced answers thxs
Old Sep 8, 2010 | 07:31 PM
lew52's Avatar
lew52
What gears are you using ....
Old Sep 8, 2010 | 10:18 PM
fordyduty's Avatar
fordyduty
when your offroading typically you want as much tq as you can. but with mudding you generally are running high rpms and thats where you want hp.So the real quesiton is how much do you plan on spending on the build?You really need to think what the truck is gonna do the most because that's the general rule of thumb when you build a motor. Also you want to know your gear ratio as mentioned above along with tire sizes. And what tranny are you mating it to?All these factors play a role when deciding what to choose for heads, cams, intakes,etc...Are you using the factory computer and if so is it speed density or mass air flow?Give us all the info you can think of. If you are doing a complete teardown then it's best to do a purpose built motor.
Old Sep 9, 2010 | 03:01 PM
Big-old-460
OK Let me explain .............. this will be a 2grand max build till next yr
I have a 460 , f 350 .. 4 door xlt ext cab. i have the e4oD tranny with automatic locking hubs and 4 x4 stick on the floor.. bogg warner transfer case .. i already have a 37 inch lift with 40 inch swamppers on it... my gear ratio atm is 5.33 dana 60 front end with a 10.25 rear ...
my truck is at school in engines class atm.. doing compression test , head leakage test etc ...
The build i want is simple .... this is my daily driver... when it snows.. drive up to the mountains off road , go ski ing etc .. when it rains drive out to asuza and off road.. mudd bogg a lil bit ... pic below is azuza soo ... i am puting new heads on, not ported... need a cam and i do have speed density , but. i can get it chiped... also would lockers help ?
heres my truck
Old Sep 10, 2010 | 03:06 AM
sufferingant
love the truck. you should check out Ford's built 460 crate engine for some inspiration. They list all of the aftermarket parts they used to make it a 521 cubic inch, 600 hp 600 lb ft monster.
Ford Racing Performance Parts - [Crate Engines]
Old Sep 10, 2010 | 05:23 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Lockers and high rpm horsepower are not going to help you on rain slick roads and snowy mountain passes in a Daily Driver.
Limited slip will help some in the mud but isn't nearly so prone to swapping ends on the road.
More compression = more torque...to a point.
And in your case that point is the limits of unported heads, stock drivetrain, the speed density injection system and pump gas.
MAF would give you more options as far as cam choices and increasing the displacement.
What kind of gains are you expecting, or shooting for?
Old Sep 10, 2010 | 07:19 AM
fordyduty's Avatar
fordyduty
being that this is your daily driver i would keep the motor on the milder side of things.Something with a compression ratio of 10:1 would still be pump gas friendly. Your cam selection will be limited due to the SD system but I used one of the comp cams offroad 4X4 camshaft with good results.(with SD your cam must supply good vacuum).You will need new lifters with any new camshaft and will want new springs as well. Roller rockers would be a nice addition. Something with a 1:7 ratio
Your heads will be the biggest problem they just aren't good flowing heads. If you plan on keeping them then you might want to try and open up the exhaust side and have the heads overhalled by a good machine shop. A good free flowing exhuast is key as well. Long tube headers would be best but they don't usally mix well with offroading so look at some good shorty headers that are tuned like gibson etc..
It would be nice to upgrade the ignition to msd.
Keep in mind that 2k sounds like a lot but when building any motor it goes very quick.
Need more coffee......
Old Sep 10, 2010 | 02:19 PM
Big-old-460
OK thxs for all the input.... after the motor is rebuild i will be Re-programing it with a new chip .. at my school ... so we will see..
my Headers are shorty , Doug thorley and i plan to .. take my heads and Open up the exhaust ports my self with a grind bit and air tool :P a engine guru guy told me the best cam will be a 540 * any advice on this cam ? .. again your rite 2k its not alot.. but the truck needs an Overhaul bad.. so any other advice might help ...
thxs guys
jayson
i will be posting pics in this thread very soon ..
Old Sep 10, 2010 | 02:22 PM
Big-old-460
No gains really.. just to refresh a tired engine.. but anything i can do to give it a little more kick would be nice... thxs
Old Sep 10, 2010 | 03:23 PM
fordyduty's Avatar
fordyduty
*540 ??????? I need more info than that.Are the heads going to be factory besides your exhuast work?Do you plan on machining the block or heads?Using factory pistons?Changing the compression ratio or keeping it factory?
Old Sep 10, 2010 | 03:58 PM
Big-old-460
OK everything is up in the air atm...
my parts list so far is .
Master engine rebuild kit ,Ford Master Engine Rebuild Kits from RPM Machine high vloume oil pump ,new distributor , new heads or Re-machined heads exhuast work only ,new Crank, high flow water pump, double roller timing chain.. advanced 12 atdc or before .. we will c ... * reprogrammed PCM/ OBD-1 chip .
stock air box with kn filter.. 10 qt modified oil pan . hope thats everything
the truck already has Doug headers on it, oil cooler , and trans cooler..
sry i am new to rebuilding i just got my ASE engines Cirt and my auto electrical ASE..
thxs for your advice
again i am just doing a Basic rebuild to breath some new life in a tired motor...
block is being sent out for .30 over bore and hone job.. etc
I have no clue on wat type of cam to run .... i want my motor to sound like this -->YouTube - 427 Ford FE
Old Sep 10, 2010 | 05:34 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Get the crank, rods, pistons, bearings and head gasket lined up before you send your block to the machine shop.
Depending on the dish of the pistons, have the shop square and deck the block for the CR you are shooting for.
Be realistic, and realize there may be times you *might* have to buy sub-par fuel.
You might want to 'subscribe' to Scotty Johnson's templates and head porting advice at the Rein"Car"nation website. Rein"Car"nation High Performance / index 2
He has done very well at the Engine Masters and for a small fee will outline the basics and save you from hitting water.
Just my 2c
Old Sep 10, 2010 | 08:45 PM
fordyduty's Avatar
fordyduty
sorry to tell you this but lumpy cams and SD efi don't mix. A cam like that won't produce enough vacuum for your SD system even with a custom chip. You really should wait on a cam selection until your block is done at the machine shop and you have the crank, rod and pistons in. If you plan on using the stock valve train then you must first know what your piston to valve clearance will be because that will determine your max lift.Also if your using a high-volume oil pump you must check the distributor engagement to the oil pump shaft and ensure the clearances are correct.Some high-volume oil pumps do not allow the distributor to seat correctly it will bolt in but will not have the proper clearance and the distributor gear will not mesh correctly with the cam. Also keep in mind that depending on the cam you use you may have to use different valve springs one's that have a higher pounds per inch rating or duel springs.
