Strange object in trans pan
Today I decided to change the transmission fluid (C6 trans), it was brown in color. Everything was going fine until I dropped the pan, a strange plastic rod with an o-ring fell out.
I looked up exploded assemblies of the C6 transmission and could not find that part in question.
Here is a picture of the object...
Ford C6 Trans Pan | Flickr - Photo Sharing!
Any idea what this is and/or where it goes? I looked everywhere and could not see a place inside the transmission that it would fit.
Also, is there supposed to be a magnet in the bottom of the oil pan?
Thanks in advance.
The plastic plug is a dipstick tube plug. It's installed at the transmission plant. When the trans is installed in the truck at the assembly plant the dipstick tube is pushed into the hole and the plastic plug falls into the pan. The first time the pan is off it is thrown away.
Wow, that means this is the first time the oil has been changed since it was built. The trans filter does have the Ford logo stamped on it, so it is probably original as well.
Yup,
The infamous "shipping plug". Unless you have a drain plug on your pan (not original equipment) then chances are...the fluid and filter had never been changed.
Why they (at the factory) chose to knock the shipping plug INTO the pan instead of just discarding it....is beyond me. It has been a source of "concern" for many a person who have never seen one before.
Flint.
