help asap
Old Sep 6, 2010 | 09:12 PM
kurt5153's Avatar
kurt5153
help asap
Okay today I was driving, went around the corner then bam it dies. When I Pope's the hood I noticed that the battery n it died now it wont start n the only fuses I found were under the steering wheel n its just the simple stuff nothing major.
Old Sep 6, 2010 | 09:16 PM
poocher pup's Avatar
poocher pup
more info please on what you did and have checked and year and all on truck.
Old Sep 6, 2010 | 09:31 PM
kurt5153's Avatar
kurt5153
88 f250 7.3l diesel 5spd. That's all I did was turned a corner n it died, n it shorted out. I don't have a tester.
Old Sep 6, 2010 | 09:33 PM
joe f350's Avatar
joe f350
will it run with wheel stait
Old Sep 6, 2010 | 09:39 PM
kurt5153's Avatar
kurt5153
What's that
Old Sep 6, 2010 | 09:52 PM
rodneywar's Avatar
rodneywar
will it run with the wheel straight is what joe said
Old Sep 6, 2010 | 10:07 PM
kurt5153's Avatar
kurt5153
Nope. It arked so bad it put a hole in the hood n I don't have power to anything
Old Sep 6, 2010 | 10:13 PM
oreocreaming's Avatar
oreocreaming
hahaha... dont worry bud. its hard to read joes typing. first things first. are you getting juice to the rest of the truck? if so then check the solenoid. the one on the firewall might be bad. jump a wire from one big post to the other and see if it cranks. wait... you said the truck wont start, but will it crank? guess i should have started with that question. if it cranks and wont fire then check for 12v to the ip. it wont fire if its not getting power.
Old Sep 6, 2010 | 10:14 PM
LCAM-01XA's Avatar
LCAM-01XA
Fried fusible link? I always hated them silly things, they do not belong in trucks period!
Old Sep 6, 2010 | 10:46 PM
rodneywar's Avatar
rodneywar
where is the hole is it over the batterys positive post then if so the battery is fried
Old Sep 6, 2010 | 11:37 PM
joe f350's Avatar
joe f350
a hole in the hood wtf
Old Sep 6, 2010 | 11:39 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Was it the passenger side battery that hit the hood?
Probably ripped the small wire from the positive post to the starter relay out, so no power to anything.
Old Sep 6, 2010 | 11:44 PM
kurt5153's Avatar
kurt5153
some time when were towing it home (via to strap) the dash lights would come on,then nothing ,then it sat for a lil n the door locks worked,then nothing.
where is that located?
ya it like 2"x1/2" ill post a pic of it tomorrow.
Old Sep 6, 2010 | 11:46 PM
kurt5153's Avatar
kurt5153
it was the drivers side, n power comes n goes threw out the truck but is not constant.
Old Sep 6, 2010 | 11:49 PM
joe f350's Avatar
joe f350
i think u took over the tittle of wose wiring mess
