Sponsored by: Real Truck
DashDAQ Questions
Old Sep 6, 2010 | 08:28 AM
kjf-250's Avatar
kjf-250
DashDAQ Questions
So i'm looking into purchasing a DashDAQ monitoring system, but I have a few questions. How do you set it up to read EGT's? From what I have read you have to have a Phidgets USB Temp Sensor like this: Phidgets USB Temperature Sensor - Thermocouple input - RobotShop Where do you mount this? Also I'm guessing that you plug the thermocouple in the exhaust manifold into this, and then run a USB cable to the DashDAQ? Please correct me if I am wrong. And when you purchase the DashDAQ do I have to purchase the ford license for it to work? Also is it able to measure turbo boost alone or do you have to run a separate wire as for that as well? Sorry for all of the questions. I have looked at the Insight and other systems, but I really want the built in GPS. The DashDAQ is $695, and then with the thermocouple and Temp. Sensor that almost another $150!
Thanks,
kjf-250
Old Oct 12, 2010 | 06:18 PM
otterlakepimp's Avatar
otterlakepimp
I just ordered the Dashdaq XL today, I believe that you do not have to run the separate cable for he EGT's. I read an earlier post on EGT's and they said you set it up for the EGRT. That comes with the basic pkg as well. i can let you know more in a couple of days. I recvd the UPS tracking # so its on its way.
Old Oct 12, 2010 | 06:24 PM
otterlakepimp
What you're looking for is EGRTA for pre turbo EGT's
Old Oct 13, 2010 | 05:49 PM
otterlakepimp
Well I recvd my DashDaq XL today, happy so far. Unfortunately the 6.0L does not have a sensor that can be read thru the OBD for EGRTA. Now thats a bummer. There is a way to get around it but you have to spend more money and drill and tap the manifold. Same way as installing an analog gauge. I was told this info from Drew tech. It does measure boost though.
jesse24spd
Nov 26, 2014 07:09 AM
ChaseN
6.7L Power Stroke Diesel
Apr 28, 2014 12:51 PM
Fulthrotl
Jul 31, 2012 11:57 PM
LaxPlaya21
6.4L Power Stroke Diesel
Aug 9, 2009 04:04 AM
SpartanDieselTech
Feb 16, 2008 05:33 PM
