Modular V10 (6.8l)
V10 Problems
Old Jan 12, 2010 | 11:17 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Holy old thread, Batman, this one started in 2003!
Old May 7, 2010 | 04:56 PM
RedNeck4Sure's Avatar
RedNeck4Sure
I have a similar problem with my v10
I have a 99 f250 4x4 v10. started out one day it died as I was slowing down to a turn on my street. I stopped and started right back up no problem. Didnt do it for like another 2 weeks down the road. That time it did it like 3 times that day. Once was going like 55mph at 1800-2000 rpm. Today though I was at stop light and as I started to accelerate it just started cutting out with very little to no acceleration what so ever. As soon as u let off the gas it would idle out. This carried on for a few minutes until i decided to pull over and shut it off. Started up and took off like nothing happened. There is service light on for Oxygen sensor bank 2 sensor 1. And also on diagnostic check it showed the front oxygen sensors are running lean. Could the O2 sensors cause this or be the TPS. I changed the fuel filter yesterday. There is no catylic convertor. Any suggestions. Its not reading any other codes on code reader. Thanks for any help. The truck does not smoke or use oil and only has 117k. I guess I will change the front two O2 sensors and see what happens.
chrlem
Oct 24, 2015 12:50 PM
03V10Excursion
May 28, 2015 09:12 AM
MTpocket$
Apr 1, 2013 01:03 PM
Gatt-Man
2004 - 2008 F150
34
Jun 6, 2011 08:06 PM
v10jim
2004 - 2008 F150
34
Nov 23, 2005 07:03 AM
