stock fuel pump vs. BIGGER fuel pump?
I just installed a regulated fuel return with a fuel bowl delete including a water separator and filter. I adjusted my regulator to 65. When standing on the throttle it never drops below 60. A friend of mine put a FASS on his duramax ( which is a completely different motor) and said his throttle response is amazing!!. My question is: even though my oem pump works fine, would putting a bigger fuel pump on increase throttle response?
on
you really should at least have 5/8 line from the tank to the pump...i know fuel lab states that...not sure about the fass....these pumps move a lot of fuel and you dont want to over heat them or they wont last long...
im going 5/8 from tank all the way to the 2 micron filter just befor the heads then 3/8 the rest of the way..the stock feed line is big enough to use as a return..but im going to do mine in 3/8 just to be safe...read your buddies instructions that came with his fass pump...just a side note though...im going with a fuel lab because i have read too many problems with the fass,,,,its your call...
No, IMO it isn't nearly enough to justify if you already have a healthy stock pump.
on
true to some but an injector that is kept full of fuel with out dropping PSI is a very happy injector and could give it a longer life....keeping the PSI from droping will add to the mid to top end of the RPM's more then help in the lower end...IMO if you want an all out race power or heavy load pulling power... then this mod would be a plus...
goose_ss4
50
11-21-2015 05:20 PM
Myfreeford
01-11-2012 10:07 AM
