engine still starving for fuel after rr
I just put a regulated return system, two external filters and two fuel pumps, and I am still have problems.
Under acceleration driving it drops to almost 20 psi and that only 1/4 throttle.
3/4 throttle drops to 10 psi and barely idel. Died twice a block away from my house of test drives.
Tank is done with mods, new cps, icp, and ipr.
Any help what I should look into next would be much appreciated.
Oh forgot to say the is no fuel leaks. At least when it idels at 60 psi I figured it be spraying out if there was one.
One strange I noticed is the aux stock electric pump gets constant high 12 almost 13 volts, and my stock mounted pump only gets low 12 and varies bad in voltage when it wants to die.
Stock located pump has wired into stock harness.
Aux pump is power via switch off a key on circuit.
Tank is full of diesel
Just don't know what to try next
Two filters and pumps - I'd need to see how they are configured, both in pictures of what they are and in a diagram as to how they are configured.
I have read about many homebrew designs that fail, even some professional designs that fail after a short time. Designing a pumping/filtration system isn't as simple as slap on some stuff that you want in there and expecting it all to work.
The biggest problem we face is the vacuum from the tank to the pump. Getting too fancy here, or skimming over the smallest detail kills fuel pressure right quick.
on
Sounds like everything is in a "series". I would have done tank to a pre pump filter (strainer), paralleled the pumps, post pump filter, on to the supply side of the heads, then out to the return regulator from heads back to tank. I did mine that way, but with a single pump in the stock location.
Pictures will help when I get off duty
