Oil filter cap
Old Oct 1, 2010 | 02:13 PM
joe blow's Avatar
joe blow
I "T"'d mine into the oil cooler off of the OEM single wire oil pressure unit. Lots of people say it is innacurate at first it was apparent that it was because it was reading 10* below ECT. I contacted the company since I had a problem with the gauge and they sent me a complete gauge/sending unit assy. I replaced both and it looks like the sending unit was also bad. Although I have no way of checking the gauge accuracy (scangauge etc) I can only ASSUME it reads correct. The reading is equal to ECT unloaded.
Old Oct 1, 2010 | 02:26 PM
gearloose1's Avatar
gearloose1
Originally Posted by Headviking
well accuracy is measured by gauges with samples of others to compare with.
OK, now we are getting somewhere.
If it is your goal to have accurate measures that you can compare with others, there is only one scientific way to do it.
Use the built in EOT / ECT gauges readings.
The reason is, if you change the sensor location, or the sensor, you are going to get an incomparable reading and Ford's recommendation for acceptable spreads goes out the window.
If you are a bold, experimental scientist type, you can hook up the gauge elsewhere (like on top of the oil filter as you did), and then religiously log the readings, AND compare it with the logged readings from the built in sensors.
But that is going to a lot of trouble.
IMHO, you are best served not by an external sensor, but by the built in sensors.
That reading is instantly comparable with everyone else readings --- and also valid with the Ford temp spread spec.
Old Oct 2, 2010 | 09:05 AM
Headviking's Avatar
Headviking
I just wanted to compare gauge readings with others. But first I need to install my sender in the same place as other.
Old Oct 2, 2010 | 11:13 AM
gearloose1's Avatar
gearloose1
Um, there is a built in EOT sender in the 6.0.
You can read it off the OBDII port.
Old Oct 2, 2010 | 03:53 PM
69cj's Avatar
69cj
That and price is why I like the ScanGauge ll. All readings from the OBD which is where the ford sensors report.
Old Oct 2, 2010 | 03:56 PM
gearloose1's Avatar
gearloose1
It would be very hard to install another sensor and then compare the readings with other people reading the factor sender.
The calibrations have to be done from scratch.
Old Oct 2, 2010 | 04:06 PM
69cj's Avatar
69cj
That's why I like the OBD sensors, esp. oil, they are internal where you want the readings. No parasitic loses getting to your a/m sensors.
Old Oct 2, 2010 | 04:08 PM
gearloose1's Avatar
gearloose1
It is very hard to get people to do good science and engineering.
Old Oct 2, 2010 | 04:12 PM
69cj's Avatar
69cj
With the OBD it is done for you. No brainer in MHO.
Old Oct 2, 2010 | 04:15 PM
gearloose1's Avatar
gearloose1
You just want inventors unemployed!
Old Oct 2, 2010 | 04:21 PM
Headviking's Avatar
Headviking
OK, OK I get it, taking the EOT from the OBDII is the best way. I on the other hand want to and have gauges installed. Like many more people I like gauges (manual, dial type). So if you can't advise me on my sender location to get engine oil temps. You are more then welcome to sit back and read what others have done, in ways of installing gauges (manual, dial type). But don't keep harping on me that the only way to get EOT is by way of OBDII. Your starting to sound like my wife.
Old Oct 2, 2010 | 04:25 PM
gearloose1's Avatar
gearloose1
Hey bud,
Above was not directed at you!
I have more sensors deployed on mine than you care to know...
From optical (cameras) to IR, to instrumentation, to sensors for whatchamacallit.
None of them OEM.
Problem is... I got to read all that data and make sense of it.
I am laughing at myself.
Best Regards,
Come to think of it... next project.. my own UAV flying overhead to scout out the road...
Old Oct 2, 2010 | 04:40 PM
  #28
69cj's Avatar
69cj
I definitely wasn't trying to do that. Just discussing b.s. with gearloose. I do hope you find what you want and pass it on.
Old Oct 2, 2010 | 04:49 PM
  #29
Headviking's Avatar
Headviking
I am still waiting for Tex to reply. He has installed the same gauge sender in a location I have just want to know his readings.
Old Oct 2, 2010 | 06:43 PM
  #30
joe blow's Avatar
joe blow
headviking PM if you want...I did it a different way
