relays are buzzing no start
Old Sep 4, 2010 | 10:20 PM
mrblonde108's Avatar
mrblonde108
i was changing radiator support and had battery rigged . moved truck and battery fell over truck shut down. now it won't start and the underhood relays are vibrating buzzing (all of them) relays don't buzz so the power or ground to them must be cycling rapidly and my fuel gage went all the way past full. not working.
Did i fry the engine controller? it's a 1993 4.9
Old Sep 5, 2010 | 06:23 AM
subford's Avatar
subford
You lost the ground at the radiator support for the fuel tanks.
It also sounds like you lost the body ground near the battery.
Also make sure the big battery ground cable goes to the engine block and not the frame.
Grounds:
Old Sep 5, 2010 | 09:06 AM
mrblonde108
thanks you da man. it's wasn't the one in the picture but there was a clip on ground i remember i removed when taking the support off. i put it back and viola! the fuel pump went on.
thanks
BlueScab
18
Jul 2, 2013 09:13 PM
fishmanndotcom
235
Nov 29, 2011 06:27 AM
mrblonde108
Sep 19, 2010 12:11 PM
mongo12
Feb 3, 2010 10:23 PM
jeff_E
Electrical Systems/Wiring
Oct 22, 2006 07:53 PM
