exhaust recomandations
Old Sep 5, 2010 | 03:14 PM
xc4jokestomper's Avatar
xc4jokestomper
yeah i get what your saying but i still dont know whic setup you said you would run?
if i go with long tube headers i pretty much either have to have a custom y pipe made at the shop with an o2 port or buy one correct?
Old Sep 5, 2010 | 03:26 PM
94MustangGT's Avatar
94MustangGT
^ Correct, you will have to go with a custom Y pipe with the long tubes.
I understand true duals have their appeal, but the same performance can be had with a solid single exhaust set up. Which is why I think true duals are useless on a 200HP truck. It only adds to the cost, not really to the performance. Look at all the 4th generation F-Bodies... They move out and they use a Y pipe set up.
Old Sep 5, 2010 | 04:01 PM
lew52's Avatar
lew52
If you use long tube headers just put the o2 sensor in the passenger side collector , you can use an H pipe with true duels but the H pipe will be to far back for the O2 to get a good reading....It works fine just reading one side ...Lew
Old Sep 5, 2010 | 10:46 PM
xc4jokestomper
i guess im going to go with long tube headers, to a single 3" pipe with a high flow cat (i foudn 3" high flows on ebay for $46 shipped.) into either a si/do muffler or split it into two glasspacks. this setup should cut down on cost since i should be able to use some of my orignal piping if some of it is 3"
does anyone see a problem with splitting it into two glasspacks? too much backpressure that way or anything?
how loud of a system am i looking at here if i got with dual glasspacks?
Old Sep 5, 2010 | 11:06 PM
94MustangGT
I would run a single glasspack, then spilt it. Also, I wouldn't skimp on the cat. Cheap ones will not last long unless you're lucky. I nice 3" with an air injection port for the air pump would be ideal.
It should sound great! Good luck.
Old Sep 5, 2010 | 11:42 PM
xc4jokestomper
air injection port for the air pump?.. you lost me with that one?
Old Sep 6, 2010 | 08:39 AM
kentuckyredneck's Avatar
kentuckyredneck
Just buy the cheap high-flow and gut it when it dies. No one will ever know and it's cheaper and louder that way.
Old Sep 6, 2010 | 03:59 PM
94MustangGT
^ Why defeat the purpose of spending money on a cat in the first place?
XC4- If you keep your air pump(also called smog pump) then the cat needs an air tube on it so everything hooks up.
Old Sep 6, 2010 | 08:01 PM
xc4jokestomper
ohhh. i didnt know about that. i didnt even know the stock cat had one lol. is it on the front cat?
Old Sep 6, 2010 | 09:19 PM
kentuckyredneck
Mustang,
He said the cats were like $46 bucks. That's cheap and he can run true duals if he wants. It'll shut the hippies up too.
Old Sep 16, 2010 | 12:24 AM
hammerhead90's Avatar
hammerhead90
just get the cheap cat and gut it before installation. Or save $ and gut the ones u take off. At least the second one.
Tyler Burdett
16
May 19, 2009 08:56 PM
FordF350Baby
Exhaust Systems
15
Jun 13, 2007 11:43 AM
95Ford302red
Exhaust Systems
Aug 15, 2003 11:17 AM
fordpower460
Exhaust Systems
Nov 27, 2001 03:27 PM
