Help! Cannot remove pivot bolt from the altenator
Old Sep 4, 2010 | 03:25 PM
stone3663's Avatar
stone3663
Question Help! Cannot remove pivot bolt from the altenator
1973 Ford F250, 360 5.9l engine. I cannot get the pivot bolt out so I can replace my altenator. the altenator spins with the pivot bolt. Any suggestions, or directions to previos threads would be helpful.
Old Sep 4, 2010 | 04:55 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Are you saying the bolt is seized in the alternator so you can't unscrew it from the block?
Old Sep 4, 2010 | 06:28 PM
stone3663's Avatar
stone3663
yeah, it was seized inside the altenator
Old Sep 4, 2010 | 06:40 PM
Terry S's Avatar
Terry S
Try soaking the threads with a penetrating oil for an hour and use an impact wrench or breaker bar on it.even if it twists off I think it can still be used as a core deposit.
Old Sep 4, 2010 | 06:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
You can try soaking it with PB balster or some other penetrating oil but as wide as the casting is I don't know if that would work. If you have access to a torch you can try heating it to break the bond.
Or you can get a six point socket and a long breaker bar and try forcing the bolt to break loose.
Old Sep 4, 2010 | 06:53 PM
83sd's Avatar
83sd
try tapping the bolt out from the back
Old Sep 4, 2010 | 09:26 PM
Tees77f150's Avatar
Tees77f150
+1, and use a BFH
Old Sep 4, 2010 | 09:34 PM
MiddleNameMUD's Avatar
MiddleNameMUD
PB BLASTER!!! soak it for an hour if that dont work heat it up gently with a torch. If you are replacing it anyways do as tees77150 said 'BFH' lol that always works just becarefull of the bracket and the rest of your surroundings. Good Luck!!
Old Sep 4, 2010 | 10:10 PM
stone3663's Avatar
stone3663
After trying to soak it several times, I decided to use a hacksaw! Not the quickest solution, but effective. Thank you for all your answers
dunkley20
Apr 2, 2013 05:07 PM
drdarts
Oct 31, 2011 05:34 PM
'88f150w/390bb
Electrical Systems/Wiring
Mar 22, 2005 08:08 PM
madman672
Apr 15, 2004 05:46 PM
DGRIMM
1997 - 2003 F150
Mar 19, 2003 11:20 AM
