Sponsored by: Auxito
Rough Idle
Old Sep 4, 2010 | 10:06 AM
raalexa's Avatar
raalexa
Rough Idle
I recently bought a 2002 F150 Supercrew 5.4L with 128000 miles on it. When I first start it up in the morning it seem to run a little rough. It shakes a little but I dont hear or feel a miss when it drive it. It's just not running as smooth as I think it should be when I first start it up in the mornings. Any ideas?
Old Sep 4, 2010 | 10:08 AM
raalexa's Avatar
raalexa
I am in Texas and it has been hot and humid so cold weather is not a factor.
Old Sep 5, 2010 | 09:06 AM
SteevenH's Avatar
SteevenH
Check your vacuum lines and clean the MAF sensor. When's the last time it had a tune up , including fuel filter?
Old Sep 5, 2010 | 09:10 AM
raalexa's Avatar
raalexa
Did you mean to say MAP sensor. Iv'e never heard of the other. I have not done anything to the truck but drive it.
Old Sep 5, 2010 | 09:26 AM
raalexa's Avatar
raalexa
BTW, what is a MAP sensor. What is it role?. I have had to change them on other vehicles but I have never asked what the hell they are.
Old Sep 5, 2010 | 03:47 PM
SteevenH's Avatar
SteevenH
It's MAF (Mass Airflow ). Located inside of your air intake duct. It uses a
hot wire sensing element to measure the amount of air entering the engine. The air passing over the hot wire causes it to cool. Consequently,
this change in temperature can be converted into an analog voltage meausred by the pcm which in turn calculates the required fuel injector pulse width. When it's dirty or bad it can cause a rough idle. Also, a vacuum problem, dirty throttle body butterfly, bad or dirty IAC valve, dirty
fuel injectors or fuel filter, plugs , cop's and so on can cause a rough idle.
Brad_9876
Jun 30, 2020 10:06 PM
400Nut
Modular V10 (6.8l)
Mar 10, 2011 10:55 PM
f250inmn
Aug 31, 2010 08:16 PM
ohardy
Oct 26, 2008 06:54 PM
