rough running 6.0
Old Oct 24, 2008 | 10:40 AM
ohardy's Avatar
ohardy
rough running 6.0
Hey guys I have a 2005 f350 on first start in the mornings it runs very rough for quite a while then when it warms up its fine. Took it to a ford service dept. and they said the inside of the fuel tank is delaminated and the tank, fuel pump, and all 8 injectors would have to be replaced for $6000. I have heard of this problem before but I'm not totally convinced because it runs fine when its warm if there were particles clogging things up wouldnt it run rough all the time?
Old Oct 24, 2008 | 10:48 AM
riggz's Avatar
riggz
Are you out of warranty already? They should eat the cost of this unless your warranty is voided or you've already hit 100k miles.
Also have you changed the fuel filters recently? See if you can have a shop pull any codes and post them up here.
Old Oct 24, 2008 | 11:11 AM
rnolloth's Avatar
rnolloth
I feel your pain!
Old Oct 24, 2008 | 12:24 PM
ohardy's Avatar
ohardy
Yup out of warranty on truck but not on the motor 56000 miles truck is completely stock so no reason the warranty would be voided the shop says that ford will not cover this because the tank is not manufactured by ford so its not their problem. Have not changed the filters in a while, I might go ahead and do that and maybe see if anything comes out. I picked the truck up already the shop didn't mention any codes. If it did throw a code, would my sct programer I have in another truck pick them up?
Old Oct 24, 2008 | 01:51 PM
riggz's Avatar
riggz
Is your fuel tank aftermarket? If it's the stock fuel tank then it doesn't matter who makes it. Hell the engine isn't made by Ford but they still repair and warranty it.
Have you run any B100 bio diesel in it?
Your SCT should be able to pull the codes.
Old Oct 24, 2008 | 03:11 PM
ohardy's Avatar
ohardy
I just replaced both filters and found what looks like metal shavings around the primary filter and found a few small shavings in the bottom of the bowl for the secondary filter so I guess that confirms that the service dept was right.
I have never run bio in this truck. Service dept advised me this has been an ongoin problem since 99 and they have seen many trucks come in like this but ford still continues to charge the owner. They have however updated the tanks in 07 according to the service manager so that tells you they know they have a problem.
Old Oct 24, 2008 | 03:38 PM
aladin sane's Avatar
aladin sane
When I had the same problem, they started by doing the inductive heating flash. This cost me a couple of mpg from the original unflashed 2003 setup. It didn't fix the problem. They replace the pasenger side injectors. It didn't fix the problem. They replaced the driver side injectors. It didn't fix the problem. They replaced the cam position sensor, and other than the lost mpg (they would not reinstall the original flash) I have not had any problems since.
Old Oct 25, 2008 | 12:58 AM
ravencr's Avatar
ravencr
Trailering
Mine's doing the same thing and blowing white smoke too on cold starts. I can't figure it out at all, plus it's whistling like a tea kettle.
Chris
Old Oct 26, 2008 | 06:54 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Woops made comment in wrong area!
Insley95
Jun 11, 2013 09:42 AM
bassin88
Oct 11, 2009 07:50 AM
weldingfreak
Jun 19, 2006 08:05 PM
jonnybronco
Mar 14, 2005 12:03 PM
