Missing at an idle
Old Sep 3, 2010 | 11:47 PM
Deerslayinrenek's Avatar
Deerslayinrenek
Missing at an idle
The truck runs great but seems to have a slight miss at an idle, an ideas? it's a 96' F-350 PSD...........Thanks
Old Sep 4, 2010 | 05:46 AM
427 fordman's Avatar
427 fordman
Do you notice any miss at higher rpm? Have you checked the valve cover gasket harnesses?
Old Sep 4, 2010 | 09:37 AM
Deerslayinrenek
no, it runs great at anything but an idle.....It's been like that for as long as i've had it which is only a month so i wouldn't know if there was any power loss.
Old Sep 4, 2010 | 11:30 AM
Action4478's Avatar
Action4478
Have you cleaned the FPR screen ?...
Old Sep 4, 2010 | 02:08 PM
Deerslayinrenek
hmm i guess i better do a search and figure out what it is and how to clean it.........I'm assuming an FPR is the fuel pump regulator?
Old Sep 4, 2010 | 04:19 PM
Action4478's Avatar
Action4478
Take out the fuel filter , inside the canister , there is a small round hole Fuel return) it has a screen in it that gets clogged with debris . Most use a que tip ,without the tip to clean it ...
Garyobray
Aug 11, 2025 10:42 AM
Encho
1978 - 1996 Big Bronco
Feb 4, 2017 01:05 PM
petrolheadjosh
Modular V10 (6.8l)
Mar 1, 2016 08:04 AM
Dale Snyder
Aug 7, 2015 08:15 PM
bigbubba87
Apr 21, 2012 09:24 PM
