rough idle
Old Sep 5, 2014 | 08:46 PM
Garyobray's Avatar
Garyobray
rough idle
A friend gave me a 1988 f250 with a 460 efi and the idle is sometimes rough like it is missing then sometimes smooth and sometimes very high-any suggestions? Thanks.
Old Sep 6, 2014 | 08:21 AM
rla2005's Avatar
rla2005
How old are the spark plugs, wires, distributor cap and rotor?
Old Sep 6, 2014 | 01:43 PM
Garyobray's Avatar
Garyobray
All that stuff appears to be very old and will be replaced on my next day off-I will post the results. Thank you.
Old Sep 6, 2014 | 03:07 PM
rla2005's Avatar
rla2005
Great place to start. High voltage items like plug wires do break down over time whether they are in use or not. Corrosion can also build up inside the the distributor cap due to moisture. A tuneup with good quality parts will cure a lot of sins from the past.
Old Sep 6, 2014 | 03:13 PM
dixie460's Avatar
dixie460
Also check out ALL the vacuum lines, including the little rubber boots. A vacuum leak can cause high idle.
Old Sep 6, 2014 | 05:13 PM
Garyobray's Avatar
Garyobray
Thanks!-that just confirms what I read elswhere so I will be checking the lines and spraying brake cleaner around the intake runners and around the throttle body. Thanks again!
Old Aug 9, 2025 | 12:09 PM
Aedhasdad's Avatar
Aedhasdad
Did this solve your issues?
Old Aug 11, 2025 | 10:13 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Highly doubtful you will get an answer from the OP. Posted 3x in his thread from 2014 and hasn’t been back.
You should start your own thread describing the problem.
Old Aug 11, 2025 | 10:42 AM
Aedhasdad's Avatar
Aedhasdad
Thanks, I did but havent had much response https://www.ford-trucks.com/forums/1...ough-idle.html
Assume from searching this is a reoccuring problem for the 460 ?
I take delivery of the truck tonight or tomorrow morning, up to this point I have had limited access to it, the trucks brakes are shot - so I bought a new master cylinder and bleed screws (one is so choked up with gunk it wont bleed) so driving it properly has not been an option.
What i know is wrong with it from the listing description:
Leaking Transmission.
What i discovered is wrong:
Rough Idle
Missfire
Motor mounts are worn out
Fuel Caps missing
Brakes failing
To get a title i need an emissions test certificate, and in its current state will fail.
What fun!
Jrogosich
Aug 18, 2010 11:56 AM
96eddie5.8
1978 - 1996 Big Bronco
Dec 17, 2006 11:31 AM
kalamazoo
Apr 4, 2005 02:56 PM
Polecat
Electrical Systems/Wiring
May 28, 2002 08:01 AM
