AWESOME MPG!!!
Old Sep 3, 2010 | 11:32 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Originally Posted by skyfox10
You just listed all of the tings I'm doing to my mountaineer (in that order). my last step is changing the ignition system components (no timing bump though). If all goes well, I'll have that done sun/mon. Out of curiosity, why do you recommend flushing the coolant system for MPG? I did mine today because it was gross.
Well, to maximize performance & mpg, I run 16BTDC. In order to do that, you want to maximize thermal transfer to avoid ping. Same reason i run stock nic plated copper core plugs rather than double platinums. To reduce combustion chamber temps. Any advance over stock 10BTDC will show improvement in both performance & MPG.
At 16BTDC you have to have all your ducks in a row. I also run a 180F thermostat to ensure lower cylinder temps, and still allow closed loop function. You only need 5-7 degrees above 180F for closed loop. Once cylinders reach thermal ping threshold it is difficult to drop below that threshold once is reached.
In engines (especially using tap or well water, Scale bakes onto the surfaces of the internal passages which impedes thermal transfer. This is why, as engines add more scale (& thermal transfer impedance), you see your temp gauge become more active, attempting to compensate for it's reduced ability to transfer heat from the engine block. This is why all radiator manufacturers recommend using "distilled" water.
Anyway, most trucks can usually tolerate 14BTDC w/ a 195F thermostat w/o a problem. Even 12BTDC would be helpful.
A product that really helps engines control engine temps, is "Water Wetter". One bottle can really help temp spikes due to increased engine load, including running the A/C.
When bumping timing, it's important to bump only a degree or two at a time. When ping is observed under load, reduce advance 2 degrees.
Also be satisfied w/ what you get w/ 87 octane (w/ an otherwise stock engine). Running a higher octane will almost alway's end up biting you in the @ss later. I do run 89 octane on road trips where I'm averaging 75-80 mph through both tanks nonstop.
Old Sep 4, 2010 | 01:32 AM
skyfox10's Avatar
skyfox10
thanks for the info. I've bumped the timing to 13 on my f150 a week ago. I'm not sure if I noticed a difference in performance or not, but a few more tanks will show if I've improved mileage. I didn't think having a MAF truck would matter, but I've heard that these trucks have a Crank Position Sensor, which might allow the computer to compensate for the timing advance.
Mdennis0_8
35
Feb 23, 2024 07:13 PM
bismic
Apr 22, 2012 10:28 PM
northernsnooker
2004 - 2008 F150
Aug 1, 2010 08:21 AM
Motown Fire
2009 - 2014 F150
Jun 14, 2010 02:25 PM
Dawgman
May 25, 2006 11:50 PM
