Have code P1151 need help
Old Sep 11, 2010 | 09:11 PM
pawpaw's Avatar
pawpaw
Well drat, I guess it was too much to expect the fix to be that straight forward.
The computer isn't happy with bank two air/fuel ratio for some reason.
Again the fuel trim isn't showing a real imbalance between banks 1 & 2.
Will your device read the O2 sensors output???? If so, post their numbers & watch their switching speed, it should be fast & averaging around about 0.6 vots.
Old Sep 12, 2010 | 03:53 PM
Eaglefixer's Avatar
Eaglefixer
well decide to just change the driver side up stream o2 sensor and then i disconnected the neg battery cable to clear code. I'll drive it tomorrow and report back. Thanks for all the help.
Old Sep 13, 2010 | 05:52 PM
Eaglefixer's Avatar
Eaglefixer
Well so far no CEL so i hope the 02 sensor fixed my problem. Again thanks to all for the help.
Old Sep 13, 2010 | 06:15 PM
pawpaw's Avatar
pawpaw
Ok good feedback.
If the passenger side O2 sensor has more than 75-100K miles on it, I'd seriously consider replacing it too, as they're normally replaced in pairs, as with age they get slow/lazy to sense/switch/feedback to the computer & it would like a balanced O2 sensor feedback from both cyl banks.
If you do decide to replace the passenger side O2 sensor, pull the battery B- cable before starting the job, to wipe the computers KAM, so it'll begin to build new fuel trim tables with the new O2 sensors input.
You might want to do the cold & warm idle computer relearn routene too, to avoid idle or driveability problems.
More thoughts for consideration.
Old Sep 13, 2010 | 06:19 PM
Eaglefixer's Avatar
Eaglefixer
not sure what the cold & warm idle computer relearn routine is?
Old Sep 13, 2010 | 06:52 PM
pawpaw's Avatar
pawpaw
A search turned this up.
Ford Truck Enthusiasts Forums - View Single Post - Again, P0401 and P1443 on a different motor
IB Tim
Oil & Lubrication
May 15, 2013 02:22 PM
RonBo
1978 - 1996 Big Bronco
Jul 25, 2002 10:29 PM
Franklin2
Nov 12, 2001 02:38 PM
redbronco2
Bronco II
Jul 27, 2001 01:48 AM
jtuck2
Electrical Systems/Wiring
Dec 23, 2000 09:25 AM
