Bad fuel pump?
Old Sep 2, 2010 | 10:25 PM
captwdhall's Avatar
captwdhall
Bad fuel pump?
I have a '96 F-150 4.9 and am having a problem with the front tank. When I try starting my truck first thing in the AM using the front tank, starts right up. If i was to turn it off and start it again, it acts like it's not getting fuel. flip over to the rear tank, starts right up. I can then start driving and switch back over with a little hesitation, but it works 9 times out of 10. I also feel like the truck lacks power when i'm pulling from the front tank. When im on the rear tank, i can almost smoke the tires. also, the check engine light is on. Autozone says its either the mass airflow sensor, or an O2 sensor.
Can anyone help me?
Old Sep 2, 2010 | 10:29 PM
captwdhall's Avatar
captwdhall
oh yea, one more thing. If i fill up the rear tank, and leave the front half full, by the time i use up all the fuel in the rear tank which seems to go very very quickly, i can switch over to the front tank, and it will be full. I cant figure that out either!
Thanks
Old Sep 2, 2010 | 11:05 PM
jplinville's Avatar
jplinville
Fuel tank selector valve...
If you do a search on this forum, you'll see that this is a common issue.
Old Sep 3, 2010 | 08:24 AM
captwdhall's Avatar
captwdhall
Would that account for the me being able to hear the rear tank running, but not the front? Replacement tips?
GeorgeL
Jan 14, 2015 03:00 PM
makattack
Nov 14, 2014 11:47 AM
joegeds
Jun 23, 2013 05:03 AM
brucers
Aug 26, 2011 07:03 PM
Nitesaber
Aug 11, 2011 10:56 AM
