Duel gas tank problems
Old Nov 12, 2014 | 04:23 PM
makattack's Avatar
makattack
I have a 95 f250 with duel gas tanks. when im using my rear tank, the front tank will slowly fill up with gas from the rear tank. is this normal? what could be causing this? also when i start the truck with the front gas tank, there is a starting problem where it takes a while to start and when it does start up, its pretty rough for a few seconds. when i start with the rear tank it has no problems. also when im driving with the front tank theres no problems.
Old Nov 12, 2014 | 04:27 PM
Nothing Special's Avatar
Nothing Special
Normal, no. But common. There's a check valve in the Fuel Delivery Module (FDM) in each tank. The check valve in your front FDM is leaking. The fix is to replace the FDM in that tank.
Old Nov 12, 2014 | 04:36 PM
rla2005's Avatar
rla2005
Very common....a post of the same issue from earlier today: https://www.ford-trucks.com/forums/1...s-problem.html
Old Nov 12, 2014 | 07:37 PM
makattack's Avatar
makattack
thanks for the link and part, i imagine i have to drop the tank out to get to the FDM, dropping the tank is not to hard but how hard is it to replace the check valve its self? am i able to just replace the valve in the module or do i have to replace the whole module? im guessing that having a bad check valve is why it doesn't want to start right away due to the pressure going back into the tank, thanks
Old Nov 14, 2014 | 07:45 AM
hotrod351's Avatar
hotrod351
have to replace the whole pump.
Old Nov 14, 2014 | 10:15 AM
makattack's Avatar
makattack
so the pump is part of the module. how long does it take to do this if i only have to drop the front tank? any suggestions on what brand i should get and which ones not to get?
Thank you
Old Nov 14, 2014 | 11:47 AM
Nothing Special
Thank you
Dropping and them reinstalling the tank are the hard parts of the job. Doing that generally takes me most of a Saturday. Actually replacing the FDM is maybe 15 minutes once the tank is out.
jonny_carson
Mar 26, 2013 01:26 PM
octaneforce
Nov 13, 2011 10:34 AM
O2bfishin
Nov 21, 2010 10:13 AM
johny b
29
Mar 22, 2007 12:03 PM
LARSON
Aug 26, 1999 02:00 PM
