Putting igmition switch back in??
Old Sep 2, 2010 | 04:03 PM
9d4's Avatar
9d4
I am replacing ignition switch. Pushed paperclip in the small hole to get the lock set out, Now I cant get the lock set in the ignition switch?? It only goes in so far and that's it?? Whats the trick to getting this back in? Thanks in advance.
Old Sep 2, 2010 | 04:09 PM
fordnut78's Avatar
fordnut78
Hello
I just fought with this last night and you need to put the paper clip back in and make sure it turns counter clockwise past the accessorie pont then mine slid in
Matt
Old Sep 2, 2010 | 04:11 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Insert the key into the lock cylinder and turn the key to the accessory position. Place the cylinder and key in the switch. Push the cylinder into the switch until it is fully seated, then turn the key to the lock position. Turn the key to check the operation of the lock cylinder.
This is from the Ford Shop Manual.
Old Sep 2, 2010 | 04:12 PM
fordnut78's Avatar
fordnut78
One other thing
if you look closely there is a roller that need to be pushed in for this to work
Old Sep 2, 2010 | 06:15 PM
9d4's Avatar
9d4
Thanx Guys, All is good
