ignition switch help please
Old Oct 30, 2009 | 08:55 PM
jmh24's Avatar
jmh24
this may be a stupid question but how do i put the new key cylinder into the housing of the ignition switch it looks like it should just slide and lock right in but that doesnt seem to be the case on a 76 f250
Old Oct 31, 2009 | 09:23 AM
restoringmy46's Avatar
restoringmy46
I believe the key has to be in the cylinder so when you slide it in the housing you turn the cylinder with the key and it should lock in.
Old Sep 2, 2010 | 04:53 PM
9d4's Avatar
9d4
Ive been trying that, doesn't seem to be working?? Its like it goes in so far and stops. I cant seem to get it to go the rest of the way in.
Old Sep 2, 2010 | 05:48 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Are you putting it in upside down? The pin hole is to the top.
Josh
Old Sep 2, 2010 | 06:16 PM
ranger429's Avatar
ranger429
If you are trying to put it in then I presume you know the button needs to be depressed on the new key cylinder and turned to the accessory position before it will fit in the ignition switch properly right?
