first years for cats???
Old Sep 3, 2010 | 06:14 PM
  #31
MiddleNameMUD's Avatar
MiddleNameMUD
Originally Posted by 25aniv
Well, you are going to need to get the running rough part of it sorted out.
Go with the 2.5" duals. The truck will breathe nice and any future changes will only add to the efficiency. The pipe size isn't too big for a 5.8 and you'll find the vast majority of custom exhaust jobs are done in 2.5" pipe. Yes, the 2 1/4 pipes will do a fine job but I bet if you ask the muffler shop to price it both ways the difference will be miniscule. Either way you will need to study up on the many variations of mufflers and get ones suited to you.
Oh, and if you are still concerned about the air pump, get the truck certified and then take it off after. You don't need an e-test and it's not originally an full emissions truck. The rough running could be something as simple as a vacuum leak but definitely fix that up.
I was going to go with a 2.5" but I only have a 2 1/4 " die for my bender, its about $25 for a 10' length of either I figured Three should do with a couple mufflers, I was thinking magnaflow or maybe do some glasspacks on the cheap. what do you recommend?? Im not far from you i'm in durham at the east end of the city. maybe after i get her plated we can hook up and check out each others rigs?? btw i could always buy another die for my bender.
thanks Adam.
Old Sep 3, 2010 | 08:53 PM
  #32
RangerHaywood's Avatar
RangerHaywood
Yeah my truck has 2.25" tru-duals on it, and just cheapo glasspacks and it sounds pretty good. It has a nice mellow rumble at idle, but she opens up and sounds like straights at the top end...
Old Sep 3, 2010 | 09:17 PM
  #33
25aniv's Avatar
25aniv
thanks Adam.
If you are set up for 2 1/4 then just use that. I don't have a clue how much a die would be although if cheap enough you will be better of with 2 1/2" in the long run. Mufflers are strickly personal preference. The muffler has to suit you!
You will see two distinctly different camps here, the glasspacks and the traditional mufflers. RangerHaywood likes the glasspacks on his and that's perfectly okay but I much prefer a dynomax bullet or two chamber Flowmaster. The point is it needs to be a sound you like. Since you are going short pipe with a very few bends, it's definitely going to make any muffler you pick that much louder. You also want to look at where your exhaust will be routed. Are you dumping the tailpipes under the truck or exiting them outside? This will add considerably to the resonance you hear in the cab especially with the exhaust dumping under the truck. If that's the case a two chamber probably isn't for you. Muffler length will also affect resonance but not so much as where you exit the pipes.
Maybe RangerHaywood can jump back in here and tell you about his exhaust? Straight back, side exit, rear exit, muffler dumps or however it's setup and also how bad it resonates in the truck. This will give you an idea at least of the different setups.
We should hook up, we're close enough! I'd really like to see your truck. Not really much of mine to see, MA#4 is down to the frame for a full restoration. If you'd like you are more than welcome to come by some day and we can just talk trucks!
Old Sep 3, 2010 | 09:27 PM
  #34
RangerHaywood
Oh alright if i have too , I have Hedman Headers on it, down to 2.25" pipes that go straight back to the 30" Long Thrush glasspacks, then they go about another 6 Feet back to some elbows on each pipes, to bend around the Class 5 Reese Hitch....and they get rid of the tingy sound that straight pipes have...
******** style="height: 344px; width: 425px"><param name="movie" value="http://www.youtube.com/v/sWMgIoiphLI?version=3"><param name="allowFullScreen" value="true"><param name="allowScriptAccess" value="always"><embed src="http://www.youtube.com/v/sWMgIoiphLI?version=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="425" height="344">*********>
Old Sep 3, 2010 | 09:32 PM
  #35
25aniv's Avatar
25aniv
[quote=RangerHaywood;9291308]Oh alright if i have too , I have Hedman Headers on it, down to 2.25" pipes that go straight back to the 30" Long Thrush glasspacks, then they go about another 6 Feet back to some elbows on each pipes, to bend around the Class 5 Reese Hitch....and they get rid of the tingy sound that straight pipes have...
See, that wasn't too bad Should help our friend mud out!
Damn nice truck by the way there Ranger
Old Sep 3, 2010 | 09:36 PM
  #36
RangerHaywood
Thanks 25aniv!!!!!!
Old Sep 3, 2010 | 10:20 PM
  #37
RangerHaywood
BTW, it doesnt resonate half as bad as it used too when it had straight pipes and carpet! Now it has mufflers and no carpet and its a ton quieter in the cab!
Old Sep 3, 2010 | 11:59 PM
  #38
sradams21's Avatar
sradams21
Ford started putting cat's on their f100's in 1975 which is why they started building the heavier f150 to get around the EPA guidelines.
My current 74 f100 4x4 360ci does not have cats but my old 75 f100 i had in high school had a factory single cat. The cat even had the original factory ford emblem staming. Should'a kept that truck....
Old Sep 4, 2010 | 10:04 AM
  #39
tbear853's Avatar
tbear853
My '77 F-150 had no cats, no "unleaded fuel only" on the fuel gage, no fuel restrictor.
The '79 F-150 Crew Cab I stripped for $150 had a cat, had the "unleaded fuel only" on the fuel gage, had a fuel restrictor.
Old Sep 4, 2010 | 05:46 PM
  #40
MiddleNameMUD
Thanks to both of you guys "25anlv & Ranger haywood" I was thinkin of doin it on the cheap for now, exhaust is one of the few things left i have to do other than a couple batt. and I am hoping thats why i need to boost it to start her.
I'll try to post some pics of her, she is a solid truck and will give most real men a bit of a chubby! LOL!! not to change the subject but I have redone all grounds in the engine bay but i still have a draw somewhere???? is the a common spot this could be or do I have to trace each wire?
Thanks again
Adam
Old Sep 4, 2010 | 05:51 PM
  #41
RangerHaywood
I am having the same problem in my truck, and i have just done the 3G 130 amp IR alternator upgrade....there isnt really anything to draw on the battery much, first would be to make sure the diodes are working correctly in the alternator, then would be to check and see if the battery actually is holding a charge and isnt internally shorting out...i dont remember what else to check on these trucks after that
Old Sep 4, 2010 | 08:52 PM
  #42
MiddleNameMUD
OK thanks i was wondering about the alternator, it is thirty years old.
i put a load test on my battery it still reads ok but I have disconnects on it without them it drains, thats not to say it still isn't the battery in conjunction with something else. I'm going to toss up another post on this subject to see if any one else can bounce some idea's at me. Keep in touch you guys have been a great help and I would like to keep in touch with ya's
Old Oct 5, 2010 | 01:20 PM
  #43
70 Bronco TX's Avatar
70 Bronco TX
I'm late to this discussion, but heck it took that long to look at my truck...
25aniv suggested this (I think) on the previous page, but there must be "partial" emissions trucks out there because my 79 F350 was made in Ontario, DSO was Phoenix, has "unleaded" sticker on the speedo, but no cat. Plus sticker under hood--original, I'm sure--says "non catalyst" truck. Certain hoses and air cleaner housing items are not present (and no holes for them, either.)
Don't know if any of this helps or has already been declared in some way but FWIW...
Old Oct 5, 2010 | 02:57 PM
  #44
steponit's Avatar
steponit
You merely have an air pump and an EGR emission style setup w/o catalytic convertors
Old Oct 5, 2010 | 04:05 PM
  #45
70 Bronco TX
Originally Posted by steponit
You merely have an air pump and an EGR emission style setup w/o catalytic converters
Yup, according to the factory manual that's about it--and you worded it much more clearly than my reference to "some stuff" !
TruckManB
New Member Introductions
Sep 24, 2015 01:55 PM
fordfirechief
Feb 20, 2015 07:48 PM
dnkensinger
39
Dec 28, 2014 03:54 PM
portico
Escape & Escape Hybrid
Oct 27, 2014 10:12 AM
habbythetabby
Apr 16, 2014 01:06 AM
