first years for cats???
Old Sep 2, 2010 | 02:14 PM
Davepig's Avatar
Davepig
78 and 79 are the years that normally had them at times from Ford, but could be earlier for like vehicles in California, as someone pointed out.
Smog on our vehicles and their age depends on the state and city you are dealing with. My part of Ohio got completely gun-shy when the EPA started fining people a few years back for installing exhaust without cats on vehicles that had them originally, so they have things they check for no matter what the owner says. If your gas gauge says "unleaded fuel only",... they are required to put on cats. If you have the gas snout that has the smaller unleaded entry with the little swing lever built into it for unleaded fuel, they are required to install cats. Those two things are their deciding factors here in my part of the country.
Gauges can be changed as well as fuel snouts to the regular fuel open design, you just gotta scour the salvage yards for the older parts and install. Maybe others could elaborate on this if there are other things they check in other states.
Old Sep 2, 2010 | 02:23 PM
25aniv's Avatar
25aniv
Originally Posted by MiddleNameMUD
Awesome thanks man!! i didn't think they needed a test but wasn't sure about the cats themselves, just dont want m.t.o to jerk me around, you know how it is. i should be able to tear off any other emissions junk on her as well then eh??
Since you said "other emissions junk" I can now assume you don't actually have a Canadian truck there. Where was your truck orginally built and sold? I should have been more clear, 79's destined for Ontario don't have cats. My truck although built in Michigan has been an Ontario truck from day one and never carried and emission system. My dad's '79 was exactly the same, destined for Ontario, no emissions. Though I'm sure the certifying officer isn't going to know the difference one way or the other. Does it have the "catalyst" sticker as berry1234 asked?
Old Sep 2, 2010 | 03:34 PM
ranger429's Avatar
ranger429
Can anybody tell me when they started putting catalitics on the 250's?
79 was the first year that federal trucks got a Catalytic converter. On a 250 it depends on GVW rating as to wether it got a cat from Ford or not.
Originally Posted by 70 Bronco TX
My 79 F350 doesn't...and shop manual doesn't indicate the F250 did (any engine), either. Was based on GVW from what i understand...
The 350's in 79 did not get a cat. The high GVW 250's also did not get a cat.
Originally Posted by 25aniv
I'm in Ontario too. The 79's here didn't have converters originally and you won't need one for your certification.
This is strictly a Canadian thing if it is true.
Old Sep 2, 2010 | 06:18 PM
MiddleNameMUD's Avatar
MiddleNameMUD
My rig was built in Ontario, the "emissions junk" I was referring to was the air pump and all the vacuum lines that look like spaghetti strewn all over the engine bay. lol I don't see a catalyst sticker due to thirty years of under coating. I want to run duals I just don't want to fork over the cash for two cats.
Old Sep 2, 2010 | 06:50 PM
Diesel_Brad's Avatar
Diesel_Brad
Like ranger429 said. It was a GVW thing. I have had 3 F350s from the 80s that had no cat from the factory. Not sure what weigh was the cut off point
Old Sep 2, 2010 | 06:56 PM
steponit's Avatar
steponit
The air pump was normal for a 78 F150-F350 everywhere in Canada
That isn't a true emission vehicle you have.
CC's were on Calif trucks
What engine is yours ?
Old Sep 2, 2010 | 07:19 PM
MiddleNameMUD
MY truck is a 250 4x4 trailer special with a 351m and def. an ontario canada manufactured truck i checked the vin.
Old Sep 2, 2010 | 07:36 PM
RangerHaywood's Avatar
RangerHaywood
GVWR was the factor in determining our trucks from when they started, from 76 or 77 till 79, the F100 had cats because any vehicle under the 6000lb weight had to have them, then the F150 came out and it weighed 6050lbs, so was the F250 and 350. So they didnt have cats.
Old Sep 2, 2010 | 07:52 PM
MiddleNameMUD
Thats great thanx everyone!!!! The dealership told me to buy the cats and punch them out. lol DONKEYS!!!
Old Sep 2, 2010 | 07:53 PM
ranger429's Avatar
ranger429
Some 79 F-250's had catalytic converters, it all depended on the GVW. IIRC there were 3 seperate GVW's for the 4x4 250's, the lighter 2 got cats and the heavier model did not.
Old Sep 2, 2010 | 08:14 PM
Dskeet6's Avatar
Dskeet6
good info learn something new every day
Old Sep 2, 2010 | 08:17 PM
25aniv's Avatar
25aniv
Here in Ontario it wasn't until '80 that full emission systems went onto trucks of any GVW. It's remotely possible a very late build '79 might have them but I know of none here.
The air pump is a common piece for the 351M but I think that was more an issue of Ford simplifying production because all the 351M / 400 cars had the pump and brackets regardless (I assume the US is that way too with cars of the era??). Cheaper to produce in the long run by putting the pump on everything.
Canadian and American trucks look the same on the outside the big majority of the time but are not always kin underneath.
302 F100 / F150's did not get an air pump until the '80s
It has an air pump but, true, not a full emission vehicle
My '79 F100 is a small block C6 combo originally and from the factory had only a pcv valve. My Dad's '79 F150 (he bought new), identical truck and only a pcv valve. It's intersesting though that both trucks are unleaded fuel but neither had the restricted fuel filler, you could easily have put either unleaded or leaded fuel down the hole. Ford did go out of their way to put three "unleaded fuel only" stickers in various spots though
One thing bugging me I can't answer definitively, if a truck has an air pump would it not have the accompanying EGR valve? This may be a US vs. Canadian buildout deal thing but a curious question. Doesn't have to be this truck, just a musing in general.....
By the way, is it running now? Did you want to convert to duals or does it not have any exhaust?
Sorry for wandering a bit!
Old Sep 3, 2010 | 12:59 PM
  #28
MiddleNameMUD
Yes its running, 'rough' till its warmed up. It only has the down pipes it had duals once apon a time due to the hangers, however they were only two inch pipe, I was thinking of steppin upto 2 1\4 unless someone convinces me differently. its a stock 5.8 with an HEI dist.
Old Sep 3, 2010 | 01:52 PM
  #29
25aniv's Avatar
25aniv
Well, you are going to need to get the running rough part of it sorted out.
Go with the 2.5" duals. The truck will breathe nice and any future changes will only add to the efficiency. The pipe size isn't too big for a 5.8 and you'll find the vast majority of custom exhaust jobs are done in 2.5" pipe. Yes, the 2 1/4 pipes will do a fine job but I bet if you ask the muffler shop to price it both ways the difference will be miniscule. Either way you will need to study up on the many variations of mufflers and get ones suited to you.
Oh, and if you are still concerned about the air pump, get the truck certified and then take it off after. You don't need an e-test and it's not originally an full emissions truck. The rough running could be something as simple as a vacuum leak but definitely fix that up.
Old Sep 3, 2010 | 05:55 PM
  #30
mamatried's Avatar
mamatried
i have my 2 79's i bought a uniersal sport cat from summit think 2.5'' pipes and thrink andretti endorsed the cat anyway it was like 35 2 years ago...and it works great to get trough smog in california...
a trick to see if they are bad is heat up the truck to normal operating temp...then shoot the laser from the heat gun on the pipe before and after the cat and then the shoot the cat itself..
the cat should be much hotter then the pipes on either side....then u can see if its working...
my cat was burnt out n was coller then the pipes on either side
