tranny
Old Sep 23, 2010 | 12:19 AM
85e150's Avatar
85e150
My '85 had a 9er, last year was '86 iirc.
8.8s have slightly different ratios, the 3.55 you mention for example vs. the 3.5, and iirc, a 3.08 vs. the 3.0 found in the 9er, as two examples.
OP can solve it all--does your axle have a removable rear cover, or a solid housing with a drop out carrier?
Old Sep 26, 2010 | 04:14 PM
85300's Avatar
85300
it is an 8.8 an it sure looks to me like it says 305
Old Sep 26, 2010 | 07:29 PM
dustybumpers's Avatar
dustybumpers
might be, I had an 86 with 3spd/od, had a 2.73. was a real pig taking off, wonderful on gas mileage though, 20+ in town!!!
Old Sep 26, 2010 | 11:10 PM
flipklos's Avatar
flipklos
I have owned two '85 F150s. One had a nine, one an 8.8. I think it is kinda a limbo era. I have seen 84s with 8.8 rears.
There is nothing wrong with the 8.8. The nine is just slightly better by design.
Old Sep 27, 2010 | 07:28 PM
85300's Avatar
85300
ok well tell me if im wrong but i think it would b easier to swap my tranny for a t18 than to change both gears an what years t18 will work?
Old Sep 27, 2010 | 08:47 PM
flipklos's Avatar
flipklos
1965-1992 T18 transmissions fit from all gas engines. I aint sure if the diesel input shaft is different.
You need the bellhousing for your engine. I think you said you had a 4spd OD and I belive that is the same bell. I aint sure where you are at but I have a NP 435 which is slightly stronger yet with an even lower first gear.
Old Sep 30, 2010 | 05:54 PM
85300's Avatar
85300
did they use the np435 too What would i look for one of those in?
Old Sep 30, 2010 | 08:14 PM
85300's Avatar
85300
does anyone know what kind of old tranny w/ a 10 spline input shaft would have the reverse gear over to the left and up?
Old Sep 30, 2010 | 09:20 PM
flipklos's Avatar
flipklos
1965-1992 F100-F800 trucks had optional NP435 trannys.
The only thing I can guess with the old 10 spline is somthing from a flathead or a Yblock. Over to the left and up says maby a MD or HD floorshift manual I belive borg warner built them for ford. There are also some spicer and ford factory designs that are this way.
Over to the right and up is a T98 4spd. T18 and the NP435 are over to the right and down.
mantta
Dec 18, 2002 09:48 PM
sparky
Nov 30, 2002 05:33 PM
youkonbob
Aug 30, 2002 03:40 PM
dzk007
Aerostar
Apr 13, 2002 11:13 AM
Jan 28, 2000 06:08 PM
