Gas Tank Relocation 1975 F20 4x4
I'm doing a frame off on 75 f250 4x4. I plan on removing the Cab tank.I would like to purchased a 19 gal OEM tank from LMC. Will that bolt onto the my frame without any mods to frame or crossmembers. Any pics of a project like this woul help.
Thanks
Bob
951 4919125
Thanks
Bob
951 4919125
Your frame is straight all the way back. I have called them and that tank is too wide for your frame. There are many threads here about that prob. I dont think any are nice enough for a frame off. Just my opinion.
I just ordered a Jaz fuel cell that will fit perfectly.
Tank part #206-022-01 is 25 1/2x25 1/2x9 so I'm pretty sure it will fit really nice. Sending unit installed. I believe the only mod to make is I have to notch a 45 fill valve to make a 90 degree that will fit between the bed and top of frame.That way I can use the existing fuel door.
I will also order hanging brackets and a short AN fuel line to get over to the frame.
Cost is $288.69
I could be wrong but I believe no movement of crossmembers will be necessary.
Summit racing had to create a part # for the custom tank assembly from Jaz and will call me tomorrow to place order. I'll let you know the new part number then.
Cost is $288.69
Thanks so much i'm having breakdown about this. I have to let the paint shop know if they can weld up the hole in the cab where the tank filler tube exited.
Thanks for the heads up on the look of those other tanks. Besides LMC wanted 379 for the 38 and and all the parts. The if it doesnt fit i pay shipping to reurn it. Is the JAZ fuel cell stainless steel ?
Please let me know the part number. I just ordered parts from Summit the other day.
Bob
cpt7576@msn.com
Bob
cpt7576@msn.com
The tank I chose is poly...they have poly within a steel powdercoated tank and alum also "I think".
Catch is the you may have to make your own brackets for that one.
Your choice of capacity and size will slightly limit you as far as which one works for you. Jaz.com
Make sure you take into account the bulge at the rear of your frame where the rear crossmember is bolted. Mine is a 73 and measures 26 inside. The tank has to fit in between or cut the bulge off. I had already powdercoated frame so I really did not want to do that.
Let you know tomorrow. I'll get you all the part#'s
You can call Jaz...they were really helpful.
You may also want to consider a tank from aerotanks.com
It's kind of expensive, but works really nice. I believe it's a 32 gal tank and fits nicely in the rear and bolts up to the bottom side of the frame. The design is a bit off though. I had to move the filler neck a bit so I could get a hose to fit. Other than that though, I like it because my truck only gets 6-7MPG and I don't have to fill up as often as I would with a small fuel cell or tank. Another option would be to move the rear crossmember back and fab a new front crossmember and place a bronco II tank back there. They fit nicely between the rails and you'll just have to fab some straps to hold it into place. I have pics of my aerotank if you want to see it.
Do you have pics of your frame and crossmember. I can send you pics of mine maybe if i can figure out this website. not very computer literate or just send me your email that easier for me.
I talked with summit the other day about the jazz tank.
Summit part # is "custom". Duh. Anyway the part #'s used were :
Tank...204-022-01
Filler neck....315-030-03
I ordered 22 gallon tank, filler neck, mounting brackets, 2 1/2 hose, and AN supply fittings to get me to the frame along with 90 degree to get the vent hooked up properly. Cost is $488.00.
If memory serves me the Aerotank was that much alone but it looks like it fits pretty tight.
I dont think I will see it til late next week due to holiday but will post pics in my 1973 Resto thread.
Tank...204-022-01
I have everyting but the tank. I cant believe it didn't show today. Ive got all the new plumbing run and am just waiting for that to button it up. I'll put pics in this post when finished.
FYI. If you get prebent lines from Inline tube be prepared for some wrestling. I chose(was forced) to get the 76 version and the bends are diff at the trans crossmember. I had to undo 4 bends to get a straighter shot. Shore looks pretty though.
Grin
Grin
