Windshield washer problem
Old Jun 7, 2016 | 09:51 AM
82fordowner's Avatar
82fordowner
Hello guys and gals, on my 82 f100 my windshield washer quit working. I checked the pump itself and it works, so I am assuming I got a broke wire some where between the washer pump and wiper switch. Or is it the switch itself? I have intermittent wipers so I guess I should price a switch. I switched from regular to intermittent so I guess I'll go under the dash and see if I have a loose connection. I may go back to the regular wiper switch which I still have, but I like the intermittent wipers. Thanks all Fred
Old Jun 7, 2016 | 04:19 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
I've had the wire break right near the plug a couple of times.
I replaced the wiper motor pigtail and it's been good since.
You might try having someone hold the washer switch while you test for power and manipulate the wires.
This is how I found where mine was broken.
Old Jun 7, 2016 | 09:03 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Remove the rubber washer hose from the jet, then try the washers. The jet can get plugged up with calcium (by not using distilled water), wax, other foreign materials.
The hose may be crimped or has collapsed internally, dying of old age.
Lower pic shows the 'whole enchilada.'
Old Jun 7, 2016 | 09:13 PM
ctubutis's Avatar
ctubutis
The official Ford diagnostics (1981 wiring which I'm pretty sure is the same in this regard for a 1982) are here:
Windshield Wiper/Washer - ???Gary's Garagemahal
Old Jun 8, 2016 | 09:08 AM
82fordowner
Thanks everyone, I'm gonna check the plugin, I think that is probably it! I'll repost once I find the problem. Thanks.
Old Jun 9, 2016 | 10:46 AM
82fordowner
Well it was the plug. So I ordered the plug! Thanks for all the help.
Old Jun 9, 2016 | 10:57 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
Glad it was easy to find and a simple repair.
Thanks for following up with your findings!
WW2N
May 26, 2016 08:11 PM
ZukBox II
Oct 11, 2010 03:01 AM
psycho72
Feb 14, 2010 07:45 AM
DutchmanAZ
Nov 26, 2002 03:31 PM
