problem with my internal slave cyclinder
Old Sep 1, 2010 | 01:20 PM
75Three90's Avatar
75Three90
ok i just got my clutch in yesterday by the time we got it in it was getting dark so we figured we would start first thing in the morning after getting everything buttoned up i add dot 3 brake fluid to the master cyclinder resivor and almost immedatlys there is clutch fluid on the ground i looked in the peep hole and it is dripping out of the front of the throw out bearing wtf happend?
Old Sep 1, 2010 | 02:01 PM
75Three90's Avatar
75Three90
bump......
Old Sep 1, 2010 | 02:24 PM
Lazy K's Avatar
Lazy K
Sounds like a bad slave cylinder. Did you replace the old one with a new Motorcraft?
Old Sep 1, 2010 | 02:26 PM
75Three90's Avatar
75Three90
no eveything was working fine so i figured it was fine as well ive never had to change one
Old Sep 1, 2010 | 02:33 PM
fordinlinesix's Avatar
fordinlinesix
Sounds like the seal is bad on that slave. Also, make sure the quick connect is good.
Old Sep 1, 2010 | 02:34 PM
Lazy K's Avatar
Lazy K
My guess would be that you are going to have to swap one in now. It would be a pity to try and get the old one to work and find that it covers your new clutch in brake fluid.
Maybe get other opinions though.
don_79f250
May 11, 2013 02:40 PM
k_nine
Feb 5, 2011 02:08 PM
Dads79
Mar 22, 2008 08:49 PM
4odd6
Jul 8, 2007 07:50 PM
