I should have said they make it difficult to do so. Getting a CARB number for an aftermarket part is getting very tough these days. The new CA converter laws are pretty tough. It would warrant taking a look to see if that is still true if you live in that fine state!
As of july, last year. They're not too picky about the Cat, as long as it passes the test. They have cow's about air intake & other engine modes though.
Stepping in late to the conversation, but rotten egg smell is almost always a sign of a bad battery. More specifically, a bad cell in a battery. It will start just fine for a bit, but it is only getting "top" charged by the alternator. Vehicles with bad battery conditions can sometimes run like turds as well.
You might have to stick your nose by the tailpipe and see if the smell is coming from there, but I would also open the hood and sniff the battery.
Hydrogen Sulfide is the bad egg smell. It can be caused by both a bad battery and a cat. But usually the cat isn't "bad". The Hydrogen Sulfide smell can be a by-product of a cat doing it's job BUT change fuel stations. Give it a few like (5) full tank fulls before you start changing parts.
Take a look at items F&G. I read that to mean if the factory used a two converter system it has to be replace with two converters not a single 3-way. But if you look in the Application Lookup chart the direct replacement is indeed a 1-for-2 swap. Go figure!
In the Cal. catalogue it's offering me either way to go. I was told there's an EPA variance granted for the F series allowing the high capacity 1 for 2. I paid less than $400 for mine, although not a magnaflow. (They also mentioned a year mustang (can't remember the year) that has 2 banks of three (6), & modding is not permitted. OUCH!!!
Hydrogen Sulfide means that the oxidizing end of your catalyst is not working, and the reduction end is reducing the sulfur from your fuel to H2S.
Either the catalyst has failed, or there is not enough oxygen getting to the cat, due to running over-rich or a failed air pump. If it is the air pump, you will only smell it after short trips.
The '97 Mustang GT I just sold came with 6 cats from the factory. I replaced those about 4 years ago with a Magnaflow X-pipe, mufflers and tailpipes. Awesome sound and picked up some ponies too.
thanks for all the info. i live in maine.im not sure what to do. i dont smell an odor every time i run it. i guess ill try different gas , maybe an additive.
Okaaaaay....What part of the above aren't you sure about? It's NOT the gas you've been using, and NO additive is going to fix the problem. You need to get those thoughts out of your head, and concentrate on the actual problem...there's something wrong with your catalytic convertor/s.
We can, and are willing to help you out here, but you have to listen to the knowledge many on this board are giving you.
