sulpher odor
Old Sep 1, 2010 | 11:37 AM
stickit06's Avatar
stickit06
sulpher odor
my 1990 f150 has an odor of sulpher after i drive afew miles it begins to idle rough. any suggestions?
Old Sep 1, 2010 | 11:52 AM
jplinville's Avatar
jplinville
check your cats...I bet they're clogged.
Old Sep 1, 2010 | 01:40 PM
Encho's Avatar
Encho
The Southernmost Mod
Well, but sulphur smells like rotten eggs, it's that the smell?. If it smells like some kind of acid, check the battery for cracks. You could also take a look at the wiring. Where do you get the smell from anyway?.
Old Sep 1, 2010 | 02:55 PM
stickit06's Avatar
stickit06
yes it smells like rotten eggs
Old Sep 1, 2010 | 03:21 PM
thomabb's Avatar
thomabb
The cat is the most likely culprit. I had an old S10 Blazer beater that smelled like that. The cat eventually blew apart.
Old Sep 1, 2010 | 03:31 PM
85e150's Avatar
85e150
Change gas stations. Gas isn't supposed to have that much sulphur in it anymore, but sometimes you get that smell even with a good cat.
Rough idle? Does it run ok otherwise, no change in power? If so, look more towards "tune up" items and the idle control valve etc.
Old Sep 1, 2010 | 05:07 PM
Sbrown's Avatar
Sbrown
Another vote for the catalytic converter. My friend had a bronco with a 351 that after two minutes you would get a headache (even driving with the windows down) from the smell and after we installed a new cat the smell was gone.
Old Sep 2, 2010 | 02:59 PM
stickit06's Avatar
stickit06
i guess ill try a different gas station thanks ive done a tune up and replaced the oxygen sensor among other parts before discovering the computor was shot
Old Sep 2, 2010 | 03:15 PM
jplinville's Avatar
jplinville
It's not the fuel...it's the cats.
Old Sep 3, 2010 | 03:32 PM
stickit06's Avatar
stickit06
ok . ive heard people removing and reaming out the cats. any ideas on this?i live in a state inspection state so they will have to be replaced. can i simply ream them?
Old Sep 3, 2010 | 04:15 PM
ymeski56's Avatar
ymeski56
Der Postmeister
Just go to a single high capacity Cat which will allow a little better flow & allowed for f-150's. Al Gore invented global warming, but we still have to breath the stuff!
Old Sep 3, 2010 | 04:35 PM
rla2005's Avatar
rla2005
If you had a previous history of an overly rich or worse yet lean condition the converters are most likely toasted. In most areas, CA is an exception, you can replace the factory two converter system with a more efficient single 3-way.
Old Sep 3, 2010 | 05:44 PM
kentuckyredneck's Avatar
kentuckyredneck
Or simply gut them, as long as it's a single O2 sensor.
Old Sep 3, 2010 | 05:51 PM
ymeski56's Avatar
ymeski56
Der Postmeister
California's ok w/ that too!
Old Sep 3, 2010 | 06:03 PM
rla2005's Avatar
rla2005
I should have said they make it difficult to do so. Getting a CARB number for an aftermarket part is getting very tough these days. The new CA converter laws are pretty tough. It would warrant taking a look to see if that is still true if you live in that fine state!
