bad tasting water
Old Jan 16, 2012 | 10:20 AM
scubajt's Avatar
scubajt
bad tasting water
My wife and I have not used our trailer much in the last year and now the water has a slight sulpher taste and smell,when using the holding tank water or the hose hookup connection. we are on well water and the house water does not taste or smell like sulpher.does anyone have an idea what woould cause this and how to fix it. thank you.
Old Jan 16, 2012 | 10:40 AM
flyhound's Avatar
flyhound
Sounds like it's the anode rod in the water heater. It sits inside the water heater and protects it from corrosion. It attracts certain elements inside the water so that the rod will corrode before the water heater does. Its common, especially when water sits in the tank for long periods of time and when using well water. For a household water heater it's a simple fix. Turn water off, drain water heather, remove old rod, usually they take a 11/16'' but I have seen some use 3/4'' or 15/16'' sockets, go to harware store and buy replacement, replace new one, turn water back on but I'm not sure since you have a RV water heater. You can also just put a plug in the hole and not replace the rod but then you risk rusting out your water heater.
Old Jan 16, 2012 | 11:28 AM
RV_Tech's Avatar
RV_Tech
When did you last chlorinate your system?
Steve
Old Jan 16, 2012 | 12:26 PM
scubajt's Avatar
scubajt
Steve
I have not done this.how do i chlorinate the system and how much chlorine should I use?
Old Jan 16, 2012 | 01:37 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Click here: How to Sanitize Your RV Fresh Water System
Old Jan 16, 2012 | 02:18 PM
RV_Tech's Avatar
RV_Tech
Originally Posted by BPofMD
Good link!
Steve
Old Jan 19, 2012 | 09:18 AM
scubajt's Avatar
scubajt
thank you for the link I flushed the system and the smell and taste are gone.
Old Jan 21, 2012 | 10:21 AM
CGMKCM's Avatar
CGMKCM
I had a problem with smelly water after letting water sit in my hot water heater for a week in between camping trips.
I now drain my water and hot water heater when I return from a trip. On the H/W tank just remove the anode and open the relief lever. Most newer R.V.s have a water tank drain valve installed so that is self explanatory.
TheDuke
Aug 25, 2018 09:26 AM
firstrider
65
Sep 16, 2017 09:39 PM
r2millers
All Things Towing
18
Jun 11, 2013 09:20 AM
enduringexplorer
Apr 8, 2005 02:42 AM
