Instrument cluster lights
Old Sep 1, 2010 | 06:34 AM
just another truck's Avatar
just another truck
The lights on the left of my instrument display have gone out.. How do I get in there??
Looking at the book, I pull the radio, pull 2 screws, then "pop" the cluster out??
Sound right?
Old Sep 1, 2010 | 07:37 AM
woodnthings's Avatar
woodnthings
Pull the radio, headlight switch, ESOF switch (If installed), then the plastic dash surround cover should pop off (12V power and the airbag deactivate are just connectors to pull loose after cover is loose) . There are 4 screws holding the cluster in. You will need to detach the trans shift indicator, but it is only a plastic latch so no big deal. You can then get to the bulbs pretty easy after removing the connector on the back of the cluster. Bulbs are in a 1/4 turn receptacle.
Old Sep 1, 2010 | 07:46 AM
just another truck
Thank you, and great instructions and pictures!!!
f100today
Jul 19, 2016 09:29 AM
BakedPotato65
1997 - 2003 F150
Sep 20, 2015 08:57 PM
landers0440
Jun 24, 2014 10:43 AM
LARIAT 85
Aug 15, 2012 06:20 PM
grelch
Jun 16, 2008 01:49 PM
