New Fuel Gauge....
Old Aug 31, 2010 | 03:37 PM
RangerHaywood's Avatar
RangerHaywood
New Fuel Gauge....
I need a new fuel gauge, to go along with my cheap sunpro gauges i have...Does anyone make one that uses the same ohm range as my 78 F150 does?
I was also wondering, was that a resistor on the back of the original instrument cluster? That little box thing that the printed circuit for the fuel gauge runs too, its like the size of a tootsie roll?
Old Aug 31, 2010 | 03:41 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you are talking about the little box that has a plug that looks like a 9v battery, thats the instrument panel voltage regulator.
The gauges won't function correctly if its not working right.
Old Aug 31, 2010 | 03:57 PM
RangerHaywood
Oh? I still have it...but would i need it if anyone made a gauge for our trucks?
Old Aug 31, 2010 | 03:58 PM
RangerHaywood
I tryed using the guts out of the old gauge and siliconed the new sunpro face on to it...but i dont think its gonna work because the sunpro has just a little bit larger sweep
Old Aug 31, 2010 | 04:02 PM
mikeo0o0o0's Avatar
mikeo0o0o0
If you're using the "guts" of the OEM fuel gauge then yes, you need to keep the IPVR for that one gauge only. The other (aftermarket) gauges, if they're electric use a full 12v for power, if they are mechanical it doesn't make any difference.
Old Aug 31, 2010 | 04:14 PM
RangerHaywood
ok, does anyone make a aftermarket gauge that works on our trucks ohm range?
Old Aug 31, 2010 | 04:26 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Pick out which gauge you would like to use and contact the manufacturer and ask them if the gauge is compatible with the stock sending unit.
Old Aug 31, 2010 | 05:48 PM
RangerHaywood
The stock sending unit out of my truck? Ok, but do you know what ohm range our sending units use?
Old Aug 31, 2010 | 06:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
I'll see if I can find what the range is and let you know.
Old Aug 31, 2010 | 06:49 PM
RangerHaywood
ok thanks mike! i think its 10-70ohms IIRC
Old Sep 1, 2010 | 10:42 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Thats correct. According to the shop manual, full is 8-12 ohms and empty is 60-86 ohms so 10-70 ohms is right in the ball park.
Old Sep 2, 2010 | 02:59 PM
RangerHaywood
Hey mike....what about this gauge? I know it has a 0-90ohm sweep, but this is the only closest ohm range gauge...if it put it in, and hooked it up, since it has a larger sweep, wouldnt it tell me(when its truly full) that it would be just under full and (when its truly empty) it would tell me i had more?
http://www.summitracing.com/parts/ATM-4314/
Old Sep 2, 2010 | 05:09 PM
mikeo0o0o0's Avatar
mikeo0o0o0
Auto Meter 4314 - Auto Meter Ultra-Lite Analog Gauges - Overview - SummitRacing.com
The ohms range would probably work like you said, a little above E when its empty and I think it would be close enough that it would read F when full. The one thing I don't know is how the sending unit in the tank will handle the extra voltage. The gauge uses 12v and IIRC the Ford gauge uses 5-6 volts.
I don't know if this would burn out the sender or not, my guess is it would but not sure.
Old Sep 2, 2010 | 06:25 PM
RangerHaywood
Ugh, this is going to be a PITA trying to find one that will work...do you know of any others that are at almost a direct replacement for the original?
Old Sep 2, 2010 | 06:35 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
The 0-90 gauge will give the opposite reading as the OEM Ford gauge which is 70-10, EMPTY TO FULL.
So, in other words with a full tank of gas the gauge will say EMPTY, as you drive the gauge will progress to FULL.
Wish it worked in real life like that.
The 0-90 is the Chevy system. Ford is opposite.
Autometer makes Ford specific Fuel gauges... part number 5416 for the Pro-Comp Series
Josh
