Hey guys new to the forum but have been reading posts for quite a while! I have a 92 f250 with a 7.3 idi n/a engine and no gauges. How high have you guys got egt's with a stock truck and no mods? I plan on towing roughly 3500 lbs up some steep grades this weekend and don't want to hurt my engine. Should I be ok without the pyrometer for a little while?
yes you should get one. its always good to have a pyrometer. even with no mods theres always a chance of melting your pistons. mount it off the #7 or #8 cylinder exhaust port on the manifold. in n/a engines those two cylinders run hotter then the other 6 because of the cdr. it sucks oil vapor that run those two cylinders hotter then the rest. you will be fine without one, but your better with! you wont get too high of egt's if you dont lug the engine. keep the rpm's up
Oh and is it ok to keep your foot on the floor with these engines? I have heard it does not hurt them but im not sure. What is considered lugging, is 2500 rpm ok to haul a lighter load with? Thank you for the reply
depends on what kinda rpm's your at and the hill, and the load. usually my egt's will sky rocket when the petal is to the floor, but back it off 1/2" and it keeps me right where i need to be. ya, 2500 is fine as long as your not petal to the metal. if your giving it more fuel then it can burn, thats when your egt's get high.
So I have one, and until my recent trip towing, never even paid attention to it. The guy I bought it from just said that when it hits 10,000, it's bad, and to let it off. And as my daily driver I never had any need to look at it as it was never a problem.
What does it "Actually" measure, and when is it considered dangerous to your engine?
Cause i got it up to like 12,000 this weekend on my trip, and rolled some SERIOUS coal for the first time, and it was just ROARING, as it passed a semi at like 135 km/h.
If you mean 1,000 degrees as in egt then that is ok but yes you will want to let off the throttle. Even 1,200 is ok but thats the limit. Hope this helped, is that what you were asking?
I was towing about 2,500 lb's, and no I don't have a turbo. Though I'm looking at purchasing another idi in lesser quality with one, stripping it, then re-selling the other truck with the parts I trade from mine.
Swipe the turbo, get it rebuilt, swipe the front bench (gf misses sitting next to me, the captains kill that), and fifth wheel hitch, maybe just part the truck out, or keep it around as preventative replacement parts.
That is a nice truck... I just paid more for an F350 just for the D60 axle! Buy it!
I would myself if this country wasn't so damn wide...
For the EGTs, Banks told me 1200 degrees max for the engine, N/A cruise should be around 800 and turbo around 600 cruising.
They also told me pyrometers aren't necessarily that accurate, and that within a 100 degrees was typical for accuracy.
Might I also add, since he will be going in steep hills, hes probably gonna be in higher elevations.
Higher elevations, less air, less power, more black smoke = higher EGT's.
Keep an eye in your miror for the smoke comming out, don't let it be to black, only a little haze of light black smoke is fine.
At some point in the rockies this summer with my N/A 6.9 motorhome, at over 9000ft. elevations, I could only give it half throttle before seing that ungodlly thick dark black smoke. 1 st gear, 25mph, riding the engine on the govenor all the way up the hill!
For $1200 you can't go wrong, even if you part it out. However.....the picture from the rear, the top of the box and the cab aren't lining up. Some possible reasons, since I would say it's parked on a pretty flat surface would be: spring issues, hangar issues, twisted frame, cab mount(s) shot, sheet metal for cab mounts shot, crosser(s) on box rotted letting the box droop, or possibly a front spring or something else in the front end causing a twist. Certain things that after a while we learn to pick up when looking at vehicles, especially if you are buying from pictures!!
well I've done a lot of reading about new IP and injectors, and adjusting the fuel by adding or removing a flat or two....
The thing is, most used trucks have over 200k miles, the one I just bought has 240k miles, and has all stock equipment, so how has the cylinders not already melted by now and destroyed the engine when they were hauling?
From everything I have read, it sounds like coming up to a hill I want to try and keep my RPMs over 2200, and if it starts to lug or drop in RPM or smoke, then drop it down a gear, and keep the rpms up....
I like the idea of having a pyrometer so I will probably just get it anyway, just wondering how needed it really is, I guess in my case I need it more simply because I am installing a new IP and injectors...
